Injector placement ? for D series ITB set up
Old Feb 10, 2005 | 06:21 AM
No-Gi's Avatar
Default Injector placement ? for D series ITB set up, not usual ?
I was wondering if it would be OK so install the CBR ITB's upside down (injectors facing down instead of up like stock ones. I think the set up will look cleaner if you do not see the injectors, fuel rail, vacum lines and such. The TPS and the fuel line fittings will also be on the stock car location.
I gues my concern is that the injectors will spray up instead of down into the head. what do you guys think?
Modified by 3_South at 4:30 PM 2/10/2005
Old Feb 10, 2005 | 12:30 PM
No-Gi's Avatar
Default Re: Injector placement ? for D series ITB set up (3_South)
bump for suggestion
Old Feb 10, 2005 | 01:02 PM
Bambooseven's Avatar
you'll be fine, they are not spraying directly into the head anyway (on most DIY setups).
Old Feb 12, 2005 | 09:12 AM
CRX-ZC's Avatar
Old Feb 12, 2005 | 10:47 AM
No-Gi's Avatar
Default Re: Injector placement ? for D series ITB set up (CRX-ZC)
Thats exactly how I want to do it. thanks man. Great minds think alike.
Old Feb 12, 2005 | 06:28 PM
DOHCsideracing's Avatar
The only reason I would think that wouldn't be a "great" idea would be that the excess fuel would always pool in the end of the injector, and eventually kind of crude it up. You know all the gas residue that shows up when fuel dries... well that would be at the end of the injector. that's the only reason I did mine on the top...
If you do it, keep us posted on if it really is a problem or not...
Adrian
Old Apr 17, 2005 | 05:39 PM
JdMotor26's Avatar
i've just now heard of this
how does the air get filtered? or does it
is this just track only or would it work on a daily driver?
thegatekeeper14
Mar 22, 2013 04:45 PM
1991_HondaAcc
Dec 7, 2009 09:00 PM
90Rexx
Dec 1, 2008 06:08 AM
crj_lll
Mar 30, 2006 09:42 AM
