Part Number Needed/Name of part
My brother has a h22 and this part got fucked up. It was bent and what seems to be a pin was pushed through the casing.
Need this part number! Thanks!!!
I dont know the part number but from hondaautomotiveparts.com they have it(genuine oem honda parts) $31.96 plus tax which is a good deal.
http://www.hondaautomotivepart...USING
Its #6
Its #6
Looking at your pics you provided and cross referencing with my helms manual. It looks like what was pushed through the casing was called the "select return pin". If you need all the internal parts of the shift arm assembly, here they are.
I don't have the oem part numbers but hope this helps you
- select arm
- spring pin
- select return spring
- 5th/reverse select spring
- select return pin
Later
- select arm
- spring pin
- select return pin
Later
Thats the shift arm cover. Honda part number 21520-P0S-010
For the Internals
For the Select Lever-------------------------- 24460-PX5-010
For the dust seal right below the lever ------91209-PE9-005
Reverse and 5th select spring ---------------24465-P0S-000
Select return spring--------------------------- 24465-P0S-000
Select Arm -------------------------------------24480-PK5-000
Spring pin --------------------------------------94305-50222
reverse lock cam -----------------------------24440-PK5-000
special bolt for reverse lock cam------------ 90028-PB6-010
Over all about 110 somethin bucks depending on who you know. (this is for the cover and all internals.)
For the Internals
JDMCRX
Jun 8, 2007 09:36 AM
