91 B16a Head on 94 Ls botom end?
nonOBD, OBDI, OBDII is all electronics (distributor, injectors, sensors). If you want THE swap guide, checkout member dplatt's own lengthly and detailed swap guide. http://www.g2ic.com/tegtips/engine/#engineguide
for ease of installation, try to get an obd2 distributor (vtec). or u can get a jumper harness to convert obd2-obd1, or obd2 to obd0. or u can just use the ls distributor and chop of one of the legs so it'll clear the vtec solenoid -- but u'll need to activate "VTEC" thru a switch, msd window activator or something.
hth.
hth.
