type r pistons in a gsr?
Old Feb 9, 2005 | 07:42 PM
greenturtle's Avatar
Default type r pistons in a gsr?
do jdm pistons go into a gsr smoothly? also will i have to upgrade anything else inside the usdm gsr? and does a type r timing belt work on a gsr? thanks for the info
Old Feb 9, 2005 | 08:04 PM
iH8RICERZ's Avatar
Default Re: type r pistons in a gsr? (greenturtle)
1. jdm ITR/CTR standard size pistons will go into a gsr block smoothly
2. Wouldnt hurt to get your block honed and whatever, also, would be smart to replace the bearings and seals, possibly new rod bolts, head bolts/studs, replace the head gasket while your at it
3. Yes, all b series vtec timing belts are the same I believe
correct me if i'm wrong...
Old Feb 9, 2005 | 08:53 PM
Sack Master's Avatar
Default Re: type r pistons in a gsr? (iH8RICERZ)
I've never put an itr piston on a gs-r rod. But I'm pretty sure they are fine. As for the cylinder. yeah same size, same wrist pin location etc etc. I've heard(again never done) ctr pistons will need to be machined to fit a gs-r rod.
Always get your block at least honed before you throw new pistons and rings in there. Replace the bearings and seals and gaskets as well. As for the head bolts. Those aren't torque to yield so you can reuse them. But nothing wrong with getting some ARP bolts or studs.
Not all b series vtec timing belts are the same. But 94+ gs-r and type r are.
Old Feb 9, 2005 | 11:04 PM
JDM_Spec's Avatar
Default Re: type r pistons in a gsr? (Sack Master)
why do you have to modify the ctr pistons to make it fit on the gsr rod
Old Feb 9, 2005 | 11:28 PM
Spirit Iron knife's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenturtle &raquo;</TD></TR><TR><TD CLASS="quote">do jdm pistons go into a gsr smoothly? also will i have to upgrade anything else inside the usdm gsr? and does a type r timing belt work on a gsr? thanks for the info</TD></TR></TABLE>
Yes, I used to have them in my old GSR, they fit fine.
Old Feb 10, 2005 | 12:31 AM
sumyungguy's Avatar
ITR pistons with a gsr head make higher compression than they do with a type r/b16 head.. any 81mm+ piston will work smoothly if your going through a good machine shop.. the ideal head would be the domes of a gsr and the ports of a type r.. gsr heads have a weired chambers on the exhaust side that enable the head, even port&polished, to flow as good as a type r
by the way i have a set of USDM ITR pistons and rods... the have just over 5000 miles on them $120shipped.. i was going to throw them in my gsr but plans have changed
gsr converters
Jun 6, 2007 09:40 AM
JDM_EK_JOE
May 18, 2006 12:17 PM
girliehonda
Jan 14, 2006 03:02 PM
iblewmyrmotor
Apr 23, 2003 08:46 PM
