This can't be good, PLZ Help me out
Old Feb 9, 2005 | 07:06 PM
Jose-aka-Pedro's Avatar
Default This can't be good, PLZ Help me out
hey whats up, I got a problem
I am only getting around 12MPG and I know thats not good
The details:
1987 Integra Ls
226,xxx Miles and origenal motor tranny etc..
I have already replaced the FI seals and I am about to send the injectors to be flow tested, cleaned, rebuilt, flow tested ( Again, they give me a before and after cc flow)and returned.
What else could be the problem, I know there are wear items but dont remember,
if you all could help me out I would be blad,
BTW mods: SRI, Exhuast, and NGK-R plugs
When I pulled the old plugs they showed even and perfect burn on all 4.
The pistons are also all silver with no build up, ( looked when I had the VC and plugs off.
I also dont go above 3.5K RPM
Thanks
Old Feb 9, 2005 | 07:21 PM
Racermech's Avatar
Default Re: This can't be good, PLZ Help me out (Street_Racer)
SEARCH. i saw a thread about this not 2 days ago, and there was a ton of reasons for low MPG
Old Feb 9, 2005 | 07:38 PM
acuracy r's Avatar
Default Re: This can't be good, PLZ Help me out (Racermech)
try to reset the ecu, or maybe your o2 sensor is bad
Old Feb 9, 2005 | 07:41 PM
RboYi's Avatar
yes is ur CEL light on? ever since my CEL light on for my sensor, it seems that ive been getting 15 miles for 1/4 tank.
Old Feb 11, 2005 | 12:06 PM
nope, my CEL isnt coming on and im about to go check the o2 sensor
Old Feb 11, 2005 | 12:22 PM
95hatchfire's Avatar
I just went through this kind of thing with my b18b... check out this post maybe it will give you ideas - also, the answer for me was my o2 - once I simply disconnected the o2 the car ran smooth again (i wasn't throwing a CEL). good luck
https://honda-tech.com/zerothread?id=1133740
Old Feb 11, 2005 | 07:36 PM
Default Re: This can't be good, PLZ Help me out (95hatchfire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hatchfire &raquo;</TD></TR><TR><TD CLASS="quote">I just went through this kind of thing with my b18b... check out this post maybe it will give you ideas - also, the answer for me was my o2 - once I simply disconnected the o2 the car ran smooth again (i wasn't throwing a CEL). good luck
https://honda-tech.com/zerothread?id=1133740</TD></TR></TABLE>
Did you take it out and leave it out? or just replace it with a new o2
Thanks, I cant check my o2 yet cuz I need the voltmeter, will sat tho, and sat ( in like, 12 hrs) im going to replace my cat with a straight pipe
Old Feb 12, 2005 | 02:56 PM
Well I was goin to replace the cat with a test-pipe but my plans changed this morning.
instead I went and cut up a whole bunch of cars, all brand new, they gave them to us cuz the cars had a small problem with them so me and like 38 other people from the Fire Dept. enjoyed cuting up cars all day,
Anyway, I dont think im going to take the time to check the o2 i think i might just replace it cuz its like 14 years old
Like i said, did you leave it out or just replace it
thanks
Old Feb 14, 2005 | 10:51 AM
sorry about not getting back quicker... I just unplugged it - you'd be surprised how well a car will run without one... try that
Old Feb 14, 2005 | 11:18 AM
#1151's Avatar
Default Re: This can't be good, PLZ Help me out (acuracy r)
maybe your gas gauge is malfunctional
Sonnboy18
Aug 14, 2009 05:25 PM
TomsEF
Apr 8, 2008 06:22 PM
preludeSRV
Feb 28, 2008 08:56 PM
turbotime
Dec 7, 2006 02:06 PM
djtony5
Apr 22, 2004 07:18 PM
