i bought two z6 tb but they are different?
the top one looks like a obd-0 tb and the bottom one a Z6 tb. if your map is not on your fire wall now just use the one with map on top. if it is on fire wall use the other.
I cant tell for sure but I looks just like the one on my old Z6. Its the same TB just no top mounted map not a big deal... If you useing this in a EF and I assuming that becuse you posted in the EF forum I would just use the First one. But like green91 said I would measure the id if there the same (and it should be) go with the first one.. But all you have to do is extend your map wires from the firewall to the tb to use the top mounted one
this intake manifold is for my mini me. I looked on the back near the top it prints "p10" seller said its a z6 but i got a 50/50 opinion on here. the second tb i bought because the first ones tps is broken. and what is "id" how do i mearssure that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoCoReX »</TD></TR><TR><TD CLASS="quote">and what is "id" how do i measure that?</TD></TR></TABLE>
"id" = Inside Diameter use a Set of Dial Calipers and Mesure the opening or turn the TB over and mesure the Butterfly
but now im not even sure the intake manifold is even a z6.....now im wondering if it is a dx mani. i did some research and z6 tb come with both top mount and firewall mount map sensor. argh...i hate buying parts that arent clearly labeld as to what they are..
they are the same. but what i am asking for is if the manifold itself is a z6....so basically do the Z6 manifolds have longer bigger runners then the DX. or are you saying if the TB matches then the manifold is a z6 thx
EK k kay
Dec 7, 2004 02:57 PM
vtecrx
Nov 28, 2002 04:28 PM
