Need helpful advice regarding spark plugs & drop in mpg
My '99 accord LX (4 cyl) has 95K miles. I changed out the spark plugs for the first time 3 wks ago with NGK brand, copper. The model I purchased was the exact same as the one recommended in the manual. I also changed the engine oil at the same time using Mobil 1, 10W-30.
I am now seeing a significant drop in the MPG. Over the past 5 years I was getting consistently 450 miles per tank (freeway miles), but over the previous two tanks since the plug change, I am seeing 325-350 miles on the tank. Huge difference!
Is this due to the spark plugs not being gapped correctly? I thought the NGKs are pre-gapped according to factory spec. Also, if I switch the plugs to the Iridiums, will that solve my problem? I read they are designed with a more forgiving gap distance.
btw, my air filter is only 2 months old, and the tire pressure is normal (34psi). my friends say the mpg drop could be caused by the oxygen sensor, fuel filter, spark plug wires and/or distributor cap. but i think the main culprit are the plugs.
Any advice will be just great...
lawrencelomanon
Honda CR-V & Element
Nov 15, 2017 10:37 AM
AlphaKennyWun
Feb 2, 2008 02:16 PM
paulthebarbarian
Feb 11, 2005 08:48 PM
