15b1 mount up to an SI tranny?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic »</TD></TR><TR><TD CLASS="quote">Yes</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civilac »</TD></TR><TR><TD CLASS="quote">Well my car is a DX 4spd, so I need new hubs?</TD></TR></TABLE>
Well then its not a dx..Its a standard model..
So you'll need si/dx hubs
Yes you will. I'll trade you a stock header for your upper part of your header and a set of control arms/hubs>
just kidding, I dont have the hubs anymore , took them to the junkyard the other day w/ the civic
Dont worry though it is only like 9 bolts per side to change the arm/hub
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civilac »</TD></TR><TR><TD CLASS="quote">what is the difference between STD and DX?</TD></TR></TABLE>
Dx has 90hp and comes either 5spd or auto
Dx comes standard with 2 mirrors
Std has 72hp and only comes 4spd manual
Std comes standard with only 1 mirror..The other mirror was an add-on
Dx models have a dx badge on the rear..
Std models have civic written in the center of the taillights with no badge on the rear like the dx..
Dx has cloth interior
STD has those ugly vinyl seats
Dx has a console around the shifter
Std has no console..Its just the shifter sticking out of the floor
Both are 1.5l d15b1/2..The std has less hp because of the restrictor plate on the throttle body..
Both have dual point fuel injection..I have to be honest you should think about converting to multi point,..Give you a much better platform..
Theres some more diferences..Search
You are very wrong mr speaker:
Some DX's that I HAVE SEEN do indeed have the little console around the ebrake
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">Dx has a console around the shifter
Std has no console..Its just the shifter sticking out of the floor</TD></TR></TABLE>
Some DX's did have only a plastic little console around the ebrake<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">Theres some more diferences..Search</TD></TR></TABLE>
And the restrictor plate people talk about isn't a restrictor plate, it is your vaccum advance diaphragm plate, which moves the diaphragm.
Other differences are t he shitty *** B1 cam which stops making power at about 4000 rpm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std »</TD></TR><TR><TD CLASS="quote">You are very wrong mr speaker:
I said the dx has a shifter console and the std doesnt..
I never said anything about the plastic around the e-brake..
Zawacki
12
Mar 8, 2008 08:44 PM
lshatch1.8
24
Jan 19, 2006 09:39 PM
