what ecu do i need
Old Feb 9, 2005 | 02:20 PM
4door93civic's Avatar
Default what ecu do i need
i have an 89 crx with an ls swap. i am doin a ls/vtec ad i dont remember what ecu i need. its still obd0 so whats the vtec obd0 ecu. thanx
Old Feb 9, 2005 | 02:27 PM
crxnj's Avatar
Default Re: what ecu do i need (4door93civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door93civic &raquo;</TD></TR><TR><TD CLASS="quote">i have an 89 crx with an ls swap. i am doin a ls/vtec ad i dont remember what ecu i need. its still obd0 so whats the vtec obd0 ecu. thanx</TD></TR></TABLE>
Either get a pr3 or pw0..
Old Feb 9, 2005 | 02:28 PM
ssl2k's Avatar
pr3 or pw0 i believe will solve your problem...
Honestly, if you ever have plans of boosting it I'd convert it to obd1 ,if you plan on uberdata like me
or if you want to stay obd0 you could pickup a ps9 ecu and run turboedit w/ 1 wire vteeek
Old Feb 9, 2005 | 02:29 PM
sleepin91teg's Avatar
I agree, pr3 pw0
Old Feb 9, 2005 | 02:40 PM
untitled's Avatar
Default Re: what ecu do i need (sleepin91teg)
pr3 or pw0 will run it but you should get either a adjustable FPR or some sort of AFC because of the added displacement. I would say get a SAFC so you can tune the motor later and squeeze some more power out of it.
Also the pw0 doest have a speed limiter or a knock sensor, so they are easier to use and you dont have to get it shipped to eliminate the speed governor. However they are harder to find, but there out there.
Old Feb 9, 2005 | 02:48 PM
ssl2k's Avatar
Default Re: what ecu do i need (untitled)
Honestly for the total cost of a pr3 or pw0 (they rape you for them) AND a Safc controller, You could get the obd0-&gt;1 harness ($59 bucks?) and a p06/p28 and chip it (if it is a p06, change it into a p28) and tune it completely with uberdata.
uberdata
Old Feb 9, 2005 | 02:49 PM
untitled's Avatar
Default Re: what ecu do i need (ssl2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssl2k &raquo;</TD></TR><TR><TD CLASS="quote">Honestly for the total cost of a pr3 or pw0 (they rape you for them) AND a Safc controller, You could get the obd0-&gt;1 harness ($59 bucks?) and a p06/p28 and chip it (if it is a p06, change it into a p28) and tune it completely with uberdata.
uberdata </TD></TR></TABLE>
most definetly.
Old Feb 9, 2005 | 03:17 PM
leech's Avatar
Or if you feel like doing some research you can just mod you PM6 or get a PS9(90-91 Civic 4dr Auto) and use TurboEdit. Last I heard 1 wire VTEC is working decently.
Old Feb 9, 2005 | 03:22 PM
ssl2k's Avatar
Default Re: what ecu do i need (leech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leech &raquo;</TD></TR><TR><TD CLASS="quote">Or if you feel like doing some research you can just mod you PM6 or get a PS9(90-91 Civic 4dr Auto) and use TurboEdit. Last I heard 1 wire VTEC is working decently.</TD></TR></TABLE>
How do you plan on engaging vtec w/ a pm6 ecu? ...
You need a PS9 if you want to do the 1 wire vtec.
Only problem doing this is that you can only "tune" up to 7800 rpms. Yeah you can rev past that, but you're fuel/timing maps will be based off of the last colum (7800rpm)
90Rexx
Apr 26, 2009 08:27 PM
1.5boosted
Dec 15, 2007 08:21 AM
1.5boosted
Nov 2, 2007 05:00 PM
Dc2 Joe
May 23, 2007 01:03 PM
