cams, cam gears, pulleys
Old Jan 16, 2002 | 02:39 PM
el_Presidente's Avatar
Default cams, cam gears, pulleys
are these worth the money if i supercharge my prelude? are they at all effective, or should i not even bother? i know what brands to get. how much gains, if any, can each of these give? thanks.
Old Jan 17, 2002 | 01:44 PM
976's Avatar
976
New User
Default Re: cams, cam gears, pulleys (el_Presidente)
What engine are you running? Different modifications gain/lower performance on different engines. For example, header on my engine can add gains of 15 HP at high RPM's, whereas on a D16 it might only add 5 HP. A supercharger would see great gains if you added wider t/b and cams, massive airflow...
Pulleys
[Modified by B21A, 10:44 PM 1/17/2002]
Old Jan 17, 2002 | 03:40 PM
Default Re: cams, cam gears, pulleys (B21A)
the h22a is the engine i'm talkin about. a header can add 15hp on yours??? on h22's, we'd be lucky to get 5 out of an aftermarket header.
Old Jan 23, 2002 | 06:21 PM
CleanCL's Avatar
i got 8hp out of my DC header and if you buy cams go with JG cams you would probably get about 15-20 hp gain
phelpsj2
Mar 21, 2012 07:44 PM
machine4321
10
Jan 13, 2008 12:25 PM
tegnchewy
12
Oct 30, 2003 02:03 PM
