Engine Ping noise at 5th gear.. Not sure please help!
Old Feb 9, 2005 | 01:58 PM
Chanus's Avatar
Default Engine Ping noise at 5th gear.. Not sure please help!
I have been noticing some high pitch clinking noise when accelerating in high gear (5th) at low speed. The noise is not loud but noticable, Should I worry about that? I think it's been like that since I bought the car brand new, but recently just curious would like to ask the experts here.
The car is 2000 TypeR with 45k miles.
Old Feb 9, 2005 | 02:10 PM
cmdr430's Avatar
Default Re: Engine Ping noise at 5th gear.. Not sure please help! (Chanus)
any mods to the car?
Old Feb 9, 2005 | 02:23 PM
Bbasso's Avatar
What Octane gas are you using?
Old Feb 9, 2005 | 02:24 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: Engine Ping noise at 5th gear.. Not sure please help! (cmdr430)
Run a higher octane fuel, reset adaptive values once you put at least a 3/4th or more tank of 93 octane fuel into vehicle.........reset adaptive values means disconnect negative battery for at least one minute, then reconnect.
Engine is pinging from low octane fuel...have u adjusted timing at all?
Old Feb 9, 2005 | 02:33 PM
Chanus's Avatar
Default Re: Engine Ping noise at 5th gear.. Not sure please help! (v-attack)
The car is still all stock, and I use 92-93 octane all the time, except a few time that I put 90 when I could not find anything higher but it was long time ago.
The thing is that it only appear when accelerate at low speed with high gear... And it wasn't a loud noise at all.
any suggestion?
Old Feb 9, 2005 | 02:36 PM
ZygSpeed's Avatar
How low of an engine speed?
Are you doing WOT runs in 5th from 1500rpm?
If you are ...
Old Feb 9, 2005 | 02:40 PM
Chanus's Avatar
Default Re: Engine Ping noise at 5th gear.. Not sure please help! (zygspeed)
Not exactly that low but 35-40mph range..
Old Feb 9, 2005 | 02:42 PM
ZygSpeed's Avatar
So, about 2200 rpm?
Learn to downshift!
Its only a 1.8 L motor, not a corvette.
Comp97GSR's Avatar
I have been dealing with the same thing, accelerating in a higher gear, part throttle at 2.5-3.5k rpms. I have narrowed it down to either a faulty injector in cylinder number 1 (just by reading plugs) or the dealer somehow re-programed my ecu after they replaced the block. (because it started shortly after that)
Old Feb 9, 2005 | 02:43 PM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">How low of an engine speed?
If you are ... </TD></TR></TABLE>
I have gone down to 1500-2000 rpm in fifth gear but thats when I'm saving gas
Comp97GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">So, about 2200 rpm?
Learn to downshift!
Its only a 1.8 L motor, not a corvette. </TD></TR></TABLE>
In your opinion this is normal then?
Old Feb 9, 2005 | 02:46 PM
Chanus's Avatar
Default Re: Engine Ping noise at 5th gear.. Not sure please help! (Comp97GSR)
I usually down-shift, but sometime you know you just need a little acceleration.
Any thing I should be worry about?
Old Feb 9, 2005 | 02:51 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">In your opinion this is normal then?</TD></TR></TABLE>
I have short shifted at times and found myself in 5th doing relatively low speeds in town.
However, I have not experienced much if anything in the way of knocking or pinging.
I do use 93-94 octane gas regularly, though.
Old Feb 9, 2005 | 02:55 PM
Chanus's Avatar
I'm not sure... it seems that after some high rpm heavy acceleration and then when I shift back to cruising and some light acceleration in 5th, it is more noticable.
Old Feb 9, 2005 | 05:08 PM
metal-x's Avatar
EGT temperature gets high on 5th gear...
Old Feb 9, 2005 | 05:47 PM
Chris F's Avatar
Mine has done it on and off since I bought it. A little pinging never killed anything. *shrug*. I'm not 100% convinced that's what it is, but it does follow the symptoms.
-Chris
Old Feb 9, 2005 | 05:48 PM
Chris F's Avatar
It's handy if you're smoking and drinking a soda, you don't have to reach for the shift lever when making a left turn. I am teh distracted driver.
Ping on!
-Chris
Old Feb 9, 2005 | 05:50 PM
Chris F's Avatar
Default Re: Engine Ping noise at 5th gear.. Not sure please help! (metal-x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by metal-x &raquo;</TD></TR><TR><TD CLASS="quote">EGT temperature gets high on 5th gear...</TD></TR></TABLE>
Que?
If you're pinging, EGT would go down... what does gear really have to do with EGT?
5th gear being coincidental with highway driving, when you're stoich and putting out a reasonable amount of power, that's why you'd see higher temps. 4th gear under the same circumstances would be about the same EGT.
neoteny
15
Jan 10, 2015 04:41 PM
yblegal
Transmission & Drivetrain
Aug 23, 2013 05:30 PM
fivespeedintegra
Honda S2000
Jul 22, 2010 03:25 AM
Rainson24
Sep 7, 2008 05:00 AM
