wtf, 2000 ex sedan with *no* srs light?
Old Feb 9, 2005 | 01:50 PM
night's Avatar
Default wtf, 2000 ex sedan with *no* srs light?
i dont mean the light not working, im talking about it literally doesnt have a spot in the cluster for the srs. there is a side bag light that works fine. car was brought in cuz they thought it wasnt working/bulb out.
does anyone know anything on this?
its really odd.
Old Feb 9, 2005 | 02:19 PM
sj993's Avatar
Default Re: wtf, 2000 ex sedan with *no* srs light? (night)
You sure it's an ex accord? Though I think even the base accord has an srs light.
Old Feb 9, 2005 | 02:38 PM
ACC0RD22's Avatar
Default Re: wtf, 2000 ex sedan with *no* srs light? (sj993)
if its got airbags its got an srs light, shine a flashlight on the cluster to see the "colored spots" you should be able to read the letters and stuff, ithe srs light will eitehr be red or yellow. i think its red tho. it should come on for a second or two during start up, so thats an indication as well
Old Feb 9, 2005 | 02:43 PM
philadd's Avatar
:scratching head:
that's odd... i've never seen any like that before... and i used to work at a dealership...
Old Feb 9, 2005 | 05:05 PM
iam7head's Avatar
it might be internally sealed LED setup, which all 6th gen v6(which is WAY different from 4cylinder if you happen to look at both side by side from behind.
I am pretty sure ford didn't forgot to put one for your accord. ops! i mention ford, because they are made the honda cluster, pop one out and you'll see a ford stamp on it.
Old Feb 10, 2005 | 05:52 AM
night's Avatar
Default Re: wtf, 2000 ex sedan with *no* srs light? (iam7head)
hmm... that makes some sense. though not on why they wouldnt use a bulb like everything else.
there was some etchings over that spot and what looked like a couple diodes.
maybe i'll pull it back out again for the hell of it.
Old Feb 10, 2005 | 06:32 AM
night's Avatar
ok, thanks for the kick in the ***. dug deeper this time and thats it.
found tape stuffed into the hole since they couldnt take a bulb out.
still find it pretty odd how in the things they made led's. like the battery, brake and oil light is also, but nothing else.
jim109
Aug 2, 2012 06:30 AM
nhldogg
Feb 26, 2010 08:16 AM
2gAccord
Jan 7, 2009 11:09 AM
bowerskd
Sep 30, 2008 11:26 AM
