dx and si spindles the same?
Old Feb 9, 2005 | 01:43 PM
silver hatch's Avatar
Default dx and si spindles the same?
i am swapping a zc into my 1991 hb. it comes with a zc tranny and i know that i need 90-93 teg axles. i have been told by some that i will need si spindles because the dx ones are smaller. butr then i have been told that dx and si are the same and all i need is the axles. it is a canadian car if that makes a difference.also will stock axles work with the zc tranny?
Old Feb 9, 2005 | 01:44 PM
EP3_05's Avatar
Default Re: dx and si spindles the same? (silver hatch)
As long as you have a dx or si you are fine. The hf and std hubs are smaller than than the Si/Dx.
Old Feb 9, 2005 | 01:45 PM
91civicEX's Avatar
Default Re: dx and si spindles the same? (91civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">As long as you have a dx or si you are fine. The hf and std hubs are smaller than than the Si/Dx. </TD></TR></TABLE>
Old Feb 9, 2005 | 01:50 PM
Gumbey75's Avatar
Default Re: dx and si spindles the same? (91civicLX)
what happens when u run hf axles on si knuckles or hf to hf knuckles?
Old Feb 9, 2005 | 02:01 PM
Targa250R's Avatar
be professional
Default Re: dx and si spindles the same? (Gumbey75)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gumbey75 &raquo;</TD></TR><TR><TD CLASS="quote">what happens when u run hf axles on si knuckles</TD></TR></TABLE>
Doesn't work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">or hf to hf knuckles?</TD></TR></TABLE>
Will not work with a transmission that uses an intermediate shaft (like the ZC trans). Will work with other D-series transmissions though.
Old Feb 9, 2005 | 02:34 PM
ssl2k's Avatar
Or if you want to be really gangsta tear apart the tranny and replace the differental and retain the ZC ring gear....You'll need a 40mm bearing differental though. EX's are 35mm If you swap the diff's you can use regular d series axles
No reason to do this unless you want to save the money of not having to deal with different axles...but you'll have more torque steer so just get the right axles.
Old Nov 29, 2005 | 10:28 AM
Blue Hybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gumbey75 &raquo;</TD></TR><TR><TD CLASS="quote">what happens when u run hf axles on si knuckles or hf to hf knuckles?</TD></TR></TABLE>
my single cam hf has Si hubs, i just got the axles with a bigger spline 1.6
Default Re: dx and si spindles the same? (gold EF)
holly carp, this post was from feb, sorry haha
e jay one
May 26, 2006 01:34 PM
vinniescrx
Oct 11, 2004 06:36 PM
JOEY F.
Aug 2, 2004 08:15 AM
sloweredcivic
Apr 27, 2004 07:20 AM
