"Walking the cup"
I see that walking the cup is a cross stitch weld resting the cup on the metal.
But isn't it best to keep the gun upright to keep good side fusion and a symmetrical profile?
Keeping the torch upright has nothing to do with symmetrical welds. Miller's website reccomends a 70 degree angle of the torch...without mention of walking the cup.
In fact, some angling towards the direction of travel helps to preheat material a bit. It also makes a slightly oblong puddle that can help keep you welding in a striaght line.
You'll read some of everything, but in the "real world" you will find that people will walk the cup with an angle closer to 45 degrees.
And keep in mind that the guys that write books are seldom the ones that can actually weld. Therefore, you can't believe everything you read in books about welding.
very little side to side angle is acceptable.
Here's an article with a little about torch angle in it.
http://www.millerwelds.com/edu...8.pdf
wade
Welding / Fabrication
15
Mar 25, 2011 02:09 PM
