97/98 vs 00/01 ITR intake cams
Old Jan 16, 2002 | 02:27 PM
HX_Guy's Avatar
Default 97/98 vs 00/01 ITR intake cams
Yes, yes I did a search but didnt find the answer Im looking for.
Does anyone have the specs for each cam? How much more power will the 00/01 cams make over the 97/98? Just 2-3 HP or 5-6+?
I might be getting a set of 97/98 ITR cams as payment for doing some engine work and am wondering if its worth replacing the intake cam with a 00/01 spec.
Old Jan 16, 2002 | 03:48 PM
B18C5's Avatar
Default Re: 97/98 vs 00/01 ITR intake cams (HX_Guy)
How do you know they even make more power? Last I heard nobody could even prove there's any difference between the 97 and 00 cams other than the part number. Even if there is a difference I doubt it would be big enough to justify using the 00 cam. If you really want to change it use a CTR cam, but even then what's the point of spending $$$ for 3 degrees duration?
Old Jan 16, 2002 | 03:51 PM
TypeR0149's Avatar
Default Re: 97/98 vs 00/01 ITR intake cams (B18C5)
Your Wrong it has been proved
you will make 2-3 in the midrange i would think, and a little up top, if it costs you alot to do it, dont
Old Jan 16, 2002 | 03:52 PM
Malice's Avatar
New User
the 00 cams are copies of the CTR cams. frank posted a pic of one. he traced the vtec lobe and compared it to a ctr cam. they were the exact same, which means about 2-3 hp over the 97 itr's. i would just go ahead and scoop up the 97's from your friend if you can get them for a good deal
Old Jan 16, 2002 | 03:53 PM
BoostinDC2's Avatar
Default Re: 97/98 vs 00/01 ITR intake cams (MaliceGSR)
from what i hear its only a couple more degrees of duration
Old Jan 16, 2002 | 03:58 PM
smerk's Avatar
New User
00/01 has 2 degrees more duration than 97/98 (and CTR has 3 degrees more duration than 97/98). I would say more like 2-3hp difference than 5-6hp, always depends on the particular engine tho.
Old Jan 16, 2002 | 06:21 PM
BABY NSX's Avatar
Default Re: 97/98 vs 00/01 ITR intake cams (smerk)
Remember as well that the 00/01 engines come equiped with different intake springs!
Old Jan 16, 2002 | 09:05 PM
B18C5's Avatar
Default Re: 97/98 vs 00/01 ITR intake cams (BABY NSX)
Stiffer ones? It goes to show all the developments I missed by not checking the board for a few months. Maybe I should have picked up the 00 cam when I got my motor blueprinted. <kicking myself in the ***> Well, there's always the next rebuild...
Old Jan 16, 2002 | 10:34 PM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
Old Jan 17, 2002 | 06:03 AM
HX_Guy's Avatar
Default Re: 97/98 vs 00/01 ITR intake cams (frank@b16a.com)
Hmm...it looks from the picture like the lift is the same...but the CTR/01 ITR cam lobe is fatter (therefore more duration?)
Old Jan 17, 2002 | 06:09 AM
Brian*'s Avatar
yeah lift is the same, only difference is the duration of the cams
Brian
Old Jan 17, 2002 | 08:38 AM
DutchITR1689's Avatar
Looks like the paper on the last picture is a bit shifted to the right.......
Old Jan 17, 2002 | 09:01 AM
HX_Guy's Avatar
Default Re: 97/98 vs 00/01 ITR intake cams (EuroITR1689)
I agree, but it could just be the angle of the picture.
Old Jan 17, 2002 | 09:52 AM
Malice's Avatar
New User
i think he did that on purpose so you can see the gap
Old Jan 17, 2002 | 10:20 AM
ITR#00-1077's Avatar
Not to sound like an idiot... I know you guys are talking about cams and HP and what not, but are you guys saying that the 00-01 ITRs are faster than the 97-98 ITRs.... just wondering....
Old Jan 17, 2002 | 10:26 AM
TypeR0149's Avatar
Default Re: 97/98 vs 00/01 ITR intake cams (hers999)
not really from what i have been told they put the more aggresive cam in there to make up for lost hp of strickter emmisions.
Old Jan 17, 2002 | 10:29 AM
CPR's Avatar
CPR
Default Re: 97/98 vs 00/01 ITR intake cams (Vegeta)
Is this the beginning of an urban legend? No disrespect for the person that did that crude tracing test but it's exactly just that...crude.
Old Jan 17, 2002 | 10:32 AM
B2FiNiTY's Avatar
Default Re: 97/98 vs 00/01 ITR intake cams (CPR)
I wonder how Honda would respond to this Q.
TypeR0149's Avatar
Somebody has miked them before and there was a 2 deg differance.
Old Jan 17, 2002 | 10:33 AM
HX_Guy's Avatar
Do you ahve some info on the matter that dissagrees with what has been said so far?
Old Jan 17, 2002 | 10:34 AM
HX_Guy's Avatar
Holy crap...its only a 2 degree differance?
Old Jan 17, 2002 | 10:39 AM
CPR's Avatar
CPR
No I don't but I don't have full scientific nor technical proof to agree.
Old Jan 17, 2002 | 11:16 AM
itr0045's Avatar
I am sure this is an urban legend. I think someone mentioned before how they were told the CTR intake cam is much more aggressive and will improve their performance over a stock ITR intake cam. Again, as someone mentioned there is only a slight difference in the duration, that's it. The pictures posted above are cool and all, but we are talking about things that need to be measured with a micrometer, not with paper and a pen. I mean how wide is the head on the pen, that traced the cam, how is the hand positioned........? The list could go on. I personally don't believe there is any difference.
-Aaron-
2001 PY Type-R 0045
Old Jan 17, 2002 | 12:36 PM
onyx00's Avatar
Default Re: 97/98 vs 00/01 ITR intake cams (itr0045)
I thought someone on this bord had put CTR cams in to an ITR and claimed they felt good gains. I believe it was MiraiZ. Ask him.
Old Jan 17, 2002 | 02:24 PM
itr0045's Avatar
Default Re: 97/98 vs 00/01 ITR intake cams (onyx00)
I just don't believe it. A 3 degree difference in the duration is not going to do hardly anything for you, especially something noticable. However, I have heard from several people that claim differently. I still don't buy it though...
BTW, here is a good resource for cam information:
http://www.g-speed.com/pbh/b16a/
