takes a couple of sec to crank teg
Old Feb 9, 2005 | 12:24 PM
gwakie's Avatar
Default takes a couple of sec to crank teg
I turn the key, and it takes a couple of seconds for the car to crank. It usually cranks right away.
Teg is coming up on 100k miles as well, so timing belt and other maitenence are in order, but is it the starter, spark plugs, or what?
Old Feb 9, 2005 | 04:48 PM
Oleg's Avatar
Default Re: takes a couple of sec to crank teg (gwakie)
usually prolonged cranking time caused by incorrect timing......get the timing gun and check the timing......only after that you can be 100 shure the problem is something else...
Old Feb 10, 2005 | 04:05 AM
JimBlake's Avatar
Clarify...
You turn the key & get NOTHING for a couple seconds? Then the starter cranks? If so, it's probably a flaky ignition switch. Or maybe a problem with the starter interlocks. Manual or automatic?
You turn the key, the starter runs immediately, but the engine doesn't start right away? That's like Oleg says, or maybe a fuel pressure problem.
Old Feb 10, 2005 | 05:12 AM
ham's Avatar
ham
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gwakie &raquo;</TD></TR><TR><TD CLASS="quote">I turn the key, and it takes a couple of seconds for the car to crank. It usually cranks right away.
Teg is coming up on 100k miles as well, so timing belt and other maitenence are in order, but is it the starter, spark plugs, or what?</TD></TR></TABLE>
do you mean it takes a couple of seconds for the car to start or for it to start cranking.
seane51
Jan 17, 2014 03:50 PM
EFS463
Aug 14, 2013 05:10 PM
mongo592
Acura TL, RL & ZDX
Nov 9, 2007 06:10 AM
LSracing94
Nov 25, 2005 10:23 PM
