At what point do you upgrade your injectors?
Old Feb 9, 2005 | 12:00 PM
TypeR0207's Avatar
Default At what point do you upgrade your injectors?
Goal is 210-220 whp all motor. I'll have mild cams in the next few months, and probably be in the 180-190whp range then. I'll also be running a VAFC-2, which will be my fuel control for now.
At what point is it a good idea to dump the stock injectors and go bigger? Does anyone know what 80% with the stock injectors and stock fuel pump equates out to as far as whp? And what is the size of the stock injectors on a '99 US model H22?
Old Feb 9, 2005 | 12:04 PM
The Phil's Avatar
Default Re: At what point do you upgrade your injectors? (TypeR0207)
i THINK (not sure) that the stock h22 injectors are running at close to 100% duty cycle at redline, so they should be upgraded for your setup.
PrecisionH23a's Avatar
At 80% duty cycle you need to upgrade your injectors. Check out http://www.rceng.com for the injector duty cycle calculation. You can always up your fuel pressure of course for a litle more flow but you probably won't need to.
The stock 99's are a 290cc. With 190whp you'll be fine with stock injectors. When you go for 220whp I hope to god you get rid of the afc.
Old Feb 9, 2005 | 12:05 PM
mgags7's Avatar
you will probably max out the stockers at about 200 whp....
you can go to rc engineering and play with their calculator to find out all the whp stuff....
your injectors are 290cc saturated.....
Old Feb 9, 2005 | 12:19 PM
matix's Avatar
Default Re: (mgags7)
Im at 208 whp on stock injectors.I will probably need to get some injectors soon. Bc im not stopping till i hit 225.
Old Feb 9, 2005 | 12:39 PM
dand39's Avatar
Not to jack your thread, but I have a similar question for HT. Would the stock injectors that came with my JDM h22a be sufficient with say... [overestimating] 230 whp on a N/A setup? If not, what size injectors would be good? Does my h22 use saturated injectors too?
Old Feb 10, 2005 | 03:42 AM
TypeR0207's Avatar
Default Re: At what point do you upgrade your injectors? (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">At 80% duty cycle you need to upgrade your injectors. Check out http://www.rceng.com for the injector duty cycle calculation. You can always up your fuel pressure of course for a litle more flow but you probably won't need to.
The stock 99's are a 290cc. With 190whp you'll be fine with stock injectors. When you go for 220whp I hope to god you get rid of the afc. </TD></TR></TABLE>
That's why I asked if anyone knew what it would be running at 80% since I know that is the limit of safe running ..... I was trying to get a sense of what was the max I could expect running the stock system.
And yes ....... I'll be running Hondata once I get to that range.
I figured it was in the 290cc range, I remember back in the R days that some of the guys would use Prelude injectors over the stock injectors for a mild upgrade (R's had 270 I believe, it's been awhile).
I've bought RC injectors before, back in the day when I started tuning/modding my Miata (back in '97), I picked up some 290's because some mechanic said I was probably running lean. On an all motor Miata that was barely cranking out 112 whp .... yeah, running lean ........
Man I've come a long way in my knowledge since then! Good thing I didn't install them ........ ended up selling them on EBay after I bought the R and sold the Miata to my Dad (after which I installed the JR supercharger on it, and it STILL didn't need injectors ........).
NC_jdmeg
Oct 30, 2014 11:18 AM
motopete
Nov 4, 2011 09:11 PM
integraRS-T
Jun 26, 2007 05:37 PM
type B16
Oct 5, 2006 04:06 AM
