Turboing a 86 CRX Si
I have a customer that wants his 86 CRX Si Turbo'd Is it possable? I have a list of partsa we are using and ideas for fuel management. Just want to kick some ideas around with someone who know the car. Please help.
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
HKS and Mugen had those kits back in the day, now you will most likely have to fabricate one yourself.
stan
stan
d16a1 from a pre 89? integra drops straight in.
if the customer doesnt wanna stop u can prolly still do it. the si is fuel injected so thats a good start. i dont know if it uses the same injection from the 88-91 models which i know most about. if you could use the injectors from newer models then you could put in some 450cc injectors and figure out some kind of management (VAFC at least). or you could just try to jack up the fuel pressure and get a new pump. either way it prolly wont run good out of boost. i converted my 91 to obd1 and used uberdata but i dont know how realistic that is for you. hope that makes sense.
since that car uses a rather prmitive fuel only ECU you can get away using an FMU and an MSD BTM will work fine
stan
stan
89CRXSIHutch
Jul 18, 2008 01:36 PM
fireant
Dec 29, 2004 05:42 PM
