94 Accord LX Braking issues
Old Feb 9, 2005 | 10:57 AM
morana622's Avatar
Default 94 Accord LX Braking issues
I have a 94 accord that when I hit the gas hard then hit the brakes I have a severe shimmy to the car. It feels as if the wheels are wobbling. If I drive the car without getting on the gas hard I do not have the problem. Also after driving the car for a while driving the car under 20 miles an hour the car feels like ithe steering is very loose. kinda like you are driving a boat.
Thanks for any help
Old Feb 10, 2005 | 08:58 AM
ricktrev's Avatar
Default Re: 94 Accord LX Braking issues (morana622)
You need to have your rotors turned or replaced.
Old Feb 10, 2005 | 09:06 AM
ricktrev's Avatar
Default Re: 94 Accord LX Braking issues (ricktrev)
Let me modify my reply. If your front end shakes during acceleration, more than likely your tie rods are severely worn. You should raise your car to where the tires are off the ground. Move your tire (either side) as if you are turning the wheel left and right. Your movement should be back and forth about an inch or two this will show you the slack in your tie rods. But if its only during braking then its your rotors. ( Make sure you steering wheel is locked in position ). Beware of severely worn front end parts such as tierods, and ball joints you dont want your wheel to dislocate from either end.
Old Feb 10, 2005 | 01:12 PM
tr3-2001SE's Avatar
My guess would be not rotors but some front end problem. I would get it to a good front end shop before it get worse. I am not use to front wheel drive but if it where rear wheel drive I would say ball joints are tie rod ends.
Old Feb 11, 2005 | 11:06 AM
morana622's Avatar
My Tie rod ends have been checked, my rotors have been turned. I am still having the same issues. I have been told that it is possible the Axels or the CV joint. Does this sound right.
Adnneby Reynoso
Dec 20, 2017 05:23 PM
Nicholas Bailey
May 15, 2016 10:51 PM
mdmax
Suspension & Brakes
Mar 19, 2013 04:15 PM
photojunky
Jan 9, 2006 02:14 PM
Earn94
Nov 19, 2004 08:34 AM
