whats the difference???
Old Feb 9, 2005 | 09:35 AM
nucivowner's Avatar
Default whats the difference???
what is the difference between a 91 b18a1 and a 93 b18a1. i work at a salvage yard and they list in my computer to be different, but they both look the same. any feedback would be a great help!!
Old Feb 9, 2005 | 09:46 AM
CLICC916's Avatar
Default Re: whats the difference??? (nucivowner)
the 91 motor is obd0, the 92-93 motor is obd1...if you wanna get the 92+ b18's, you also need that year's ecu to run everything (as well as a 4 wire o2 sensor, distributor from that year)
EP3_05's Avatar
The 91 is OBD0 and has 130hp
The 93 is OBD1 and has 140 hp
Old Feb 9, 2005 | 10:01 AM
nucivowner's Avatar
Default Re: whats the difference??? (91civic)
are parts interchangable? i mean, can i turn the 93 obd1 engine into a obd0 engine. i have all the parts from the 91 and i want to use the 93 block and head(which has fewer miles) and change whatever i need to make it work as an obd0.
Old Feb 9, 2005 | 10:04 AM
EP3_05's Avatar
Yeah b series parts are interchangeable so you can run a 93 engine as an OBD0 engine but I would reccommend running OBD1
Old Feb 9, 2005 | 10:08 AM
nucivowner's Avatar
thanks for the help!! i would love to run obd1 but im getting all the stuff for an obd0 for $150!!!! all i gotta do now is find a b-series trany and im good to go!!
Old Feb 9, 2005 | 02:44 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nucivowner &raquo;</TD></TR><TR><TD CLASS="quote">what is the difference between a 91 b18a1 and a 93 b18a1. i work at a salvage yard and they list in my computer to be different, but they both look the same. any feedback would be a great help!!</TD></TR></TABLE>
90-91 is pre-obd and has 130hp
92-93 is obd1 and has 140hp
Both have cable trannys..
The 92-93 has more agressive cams ..
StockDC2
Aug 22, 2008 05:38 AM
slowassciv33
Nov 3, 2005 02:38 PM
honcrx91si
Aug 8, 2005 08:23 PM
91lsteg
May 31, 2005 06:38 PM
IhateMy93BlackHatch
Jan 12, 2003 06:05 PM
