mugen active gate v.s. the nsx setup q's?
Old Feb 9, 2005 | 09:20 AM
DC2 to AP2's Avatar
Default mugen active gate v.s. the nsx setup q's?
just wondering what you guys would prefer and the reason why. i have 96 nsx calipers with legend rotors at the moment and have a chance to upgrade for pretty cheap (100 bucks or so). would you do it? thanks in advance.
Old Feb 9, 2005 | 09:25 AM
ZygSpeed's Avatar
Default Re: mugen active gate v.s. the nsx setup q's? (imola-red dc2)
So, youre saying you could "step-up" the the Mugen active gate setup for an additional $100?
I'd think that would be a no-brainer, since Yoshi and Mike seem to have had very good success with the active gate after having used the NSX/Legend kit.
Old Feb 9, 2005 | 09:32 AM
yoshi234's Avatar
I shoot brides
Default Re: mugen active gate v.s. the nsx setup q's? (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">So, youre saying you could "step-up" the the Mugen active gate setup for an additional $100?
I'd think that would be a no-brainer, since Yoshi and Mike seem to have had very good success with the active gate after having used the NSX/Legend kit.</TD></TR></TABLE>
ditto.
the bionic R's nsx got removed last week and switched to AGB as well
Old Feb 9, 2005 | 09:35 AM
jdmspoonitr's Avatar
Default Re: mugen active gate v.s. the nsx setup q's? (yoshi234)
What about using the agb system withe the NSX two piston calipers?
Old Feb 9, 2005 | 09:36 AM
DC2 to AP2's Avatar
yeah its only another 100 out of my pocket for them. the only for me is the use of 16in wheels. stock itr wheels dont over them? how good is the s2000 caliper vs.s the nsx ones?
Old Feb 9, 2005 | 09:37 AM
DC2 to AP2's Avatar
Default Re: mugen active gate v.s. the nsx setup q's? (jdmspoonitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote">What about using the agb system withe the NSX two piston calipers?</TD></TR></TABLE>
is that possible?
Old Feb 9, 2005 | 08:35 PM
Kengs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imola-red dc2 &raquo;</TD></TR><TR><TD CLASS="quote">yeah its only another 100 out of my pocket for them. the only for me is the use of 16in wheels. stock itr wheels dont over them? how good is the s2000 caliper vs.s the nsx ones? </TD></TR></TABLE>
Some guy in the Appearance forum used the AGBs with 15in CE28 wheels.
Old Feb 9, 2005 | 11:08 PM
DC2IntegraTypeR's Avatar
Isn't the AGB system basically S2000 calipers?
Old Feb 9, 2005 | 11:09 PM
Default Re: (THEINTEGRATION)
with really nice rotors and nice lines and brake pads
Old Feb 10, 2005 | 01:51 AM
Chris93Si's Avatar
Do it, then have Yoshi take pixors w/ JDM girly magazine in the background
&lt; Who still has those pixors on his comp
Old Feb 10, 2005 | 09:59 AM
GPNY's Avatar
Default Re: mugen active gate v.s. the nsx setup q's? (Chris93Si)
OK need to Clarify here - Are you getting a real active gate system? It seems that the biggest advantages to the active gate are the rotors/lines/pads.
The calipers are very ordinary, and if you wanted you could get the same size rotors as the Active gate by doing a 1999/up RL calipers and rotor setup.
The NSX calipers are also 2 piston, whereas S2K are 1 piston.
I don't know about the NSX calipers bolting up to s2k brackets, but I know that Legend calipers will bolt up to ITR, Legend, and RL Brackets (though ITR Brackets are narrower and wont accept a 28mm disc)
Old Feb 11, 2005 | 09:55 PM
yoshi234's Avatar
I shoot brides
Default Re: mugen active gate v.s. the nsx setup q's? (GPNY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GPNY &raquo;</TD></TR><TR><TD CLASS="quote">The calipers are very ordinary</TD></TR></TABLE>
no they aren't!
y shi - who just wanted to post a pic
Old Feb 12, 2005 | 11:44 AM
Kengs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoshi234 &raquo;</TD></TR><TR><TD CLASS="quote">
y shi - who just wanted to post a pic </TD></TR></TABLE>
You need to work on your focusing skillz Yosh
Old Feb 12, 2005 | 12:29 PM
Seedc2's Avatar
Default Re: mugen active gate v.s. the nsx setup q's? (Kengs the "OG" JDM Junkie)
your phocusing s0x
Old Feb 12, 2005 | 12:35 PM
SMZ GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kengs the "OG" JDM Junkie &raquo;</TD></TR><TR><TD CLASS="quote">
You need to work on your focusing skillz Yosh </TD></TR></TABLE>
Thats exactly what I was going to say, but didn't
BTW: if you want to sell your current setup, let me know
Modified by SMZ GSR at 1:53 PM 2/12/2005
Old Feb 13, 2005 | 10:54 PM
yoshi234's Avatar
I shoot brides
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kengs the "OG" JDM Junkie &raquo;</TD></TR><TR><TD CLASS="quote">You need to work on your focusing skillz Yosh </TD></TR></TABLE>
i sure do!
Old Feb 13, 2005 | 10:57 PM
Dr. EKology's Avatar
Default Re: mugen active gate v.s. the nsx setup q's? (SMZ GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMZ GSR &raquo;</TD></TR><TR><TD CLASS="quote">
Get in line buddy
Old Feb 13, 2005 | 11:50 PM
SMZ GSR's Avatar
Default Re: mugen active gate v.s. the nsx setup q's? (EKology)
*pushes EKology down*
Your place will do
Old Feb 14, 2005 | 12:13 AM
slammed_93_hatch's Avatar
IMO go with what has the ability to lock up your tires, and wont fade.
I have watched your build up and doens't look like its going to be a track car, so id just use the cheaper of them, there both good.
Mugen
pro
AGB has bigger cooling vent's
Con
fckn ***** expensive to replace and not something you can pick up easily.
OEM
pro
NSX has 2 piston caliper, which equals better pedal modulation.
replacement parts rae cheaper
cons
still expinsive
I'd go with the OEM nsx setup, cheap and will still get you good results, and i doubt you'd ever be able to push the car past the limits of that setup
mynameizstitch
Nov 11, 2009 11:07 AM
TYPERman2001
Dec 26, 2007 09:33 AM
BrakeExpert
15
Jul 4, 2007 07:48 PM
dai
Oct 25, 2006 01:04 PM
5lugNinja
Mar 31, 2004 09:17 AM
