Welding Question
Old Feb 9, 2005 | 06:11 AM
DSPDA3's Avatar
Default Welding Question
I'm looking for some flanges for an exhaust mod, and was curious what flange ID I should look for. From a welding standpoint, is it better for the flange ID to be larger than the pipe OD? Or smaller than the pipe OD? If smaller than the OD, this would affect exhaust flow slightly, I would think...
Old Feb 9, 2005 | 06:17 AM
Kaan's Avatar
Loved
Community Favorite
Default Re: Welding Question (DSPDA3)
if you make the flange smaller... it will restrict it but then you can "port it" back to the right size. if you have it the same size you can just weld the seem on the ouside or "butt" weld the inside. If its slightly big you might blow holes (if you arent used to welding) and it might be a little harder to place it exactly where you want.
MidShipCivic
Welding / Fabrication
12
Mar 5, 2010 05:31 AM
Raatzio
Jun 8, 2005 09:12 AM
jhota
Nov 25, 2004 08:32 AM
FastNFurious
Feb 4, 2004 01:47 PM
Chip398193
Apr 14, 2002 08:05 PM
