LS CRX... need 91 LS Vacuum Diagram!
Old Feb 9, 2005 | 04:20 AM
ne3ek's Avatar
Default LS CRX... need 91 LS Vacuum Diagram!
I just swapped an ls into my 89dx and i used the LS map sensor/solenoid cluster.
I only hooked up the MAP so the other to purge valves are disconected, they have vacuum going to them but they are disconected.
I want a vacuum diagram for a 91 ls, and I want to know what 2 things are.. a. the piece on the t/b that hooks into the throttle cam and uses vacuum, and b. the other unit that sits in the middle of the manifold and says "UP" and has 2 lines going into it.
Also how do I hook up those valves? I only use ne now right? DO I re-use the dx one? And just attatch the LS map to it? Please help this bitch barely idles!
Old Feb 9, 2005 | 03:49 PM
ne3ek's Avatar
Default Re: LS CRX... need 91 LS Vacuum Diagram! (ne3ek)
help!
Old Feb 9, 2005 | 05:26 PM
CRX_1.8T's Avatar
Here you go dude, this is the diagram that the state ref gave me to refer to after I passed smog. The '90-'91 have the same layout. Hope this helps...
Old Feb 10, 2005 | 03:55 AM
ne3ek's Avatar
Default Re: LS CRX... need 91 LS Vacuum Diagram! (CRX_1.8T)
word thanks.. a couple questions..
what does the air boost valve do?
and Which one of those solenoids on the firewall do i hook up? Or do i use the dx one?
Old Feb 10, 2005 | 08:22 AM
ne3ek's Avatar
noone knows?
Old Feb 10, 2005 | 03:24 PM
ne3ek's Avatar
Old Feb 11, 2005 | 10:50 PM
ne3ek's Avatar
Old Feb 11, 2005 | 10:53 PM
CRX_1.8T's Avatar
Hook up all of the solenoids, make sure the smog stuff you have is for a 90-91 Integra though.
v8hnta
Apr 9, 2008 01:48 PM
KillerBTeg
Jan 10, 2005 05:40 PM
Flexmyrex
Oct 13, 2002 11:24 AM
