I might be picking up an Si or is it?
A friend of mine has a white, i believe 89 or 90 crx, I havent seen it yet. He says its a 1.6 with mpfi. So im guessing it has to be an Si becuz the previous owner isnt the kind of person to do a swap. The only thing i dont know about is the interior. Its blue, so were there even Si's made with the white exterior and blue interior?
Ive searched to **** and back and cant find **** about factory color options.
you havent seen the car in person? have you seen pics? if your not going to look at it soon ask for the vin/chassis code and some pics. you can check those with the si and if they are different then its not an si.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 »</TD></TR><TR><TD CLASS="quote">The only thing i dont know about is the interior. Its blue, so were there even Si's made with the white exterior and blue interior?</TD></TR></TABLE>
No. All Si models had a black interior. The white HFs and DXes had the blue interior.
Just like the others have stated, the blue interior is a dead giveaway that it is a HF or DX.
But once in a blue moon, people might put HF/DX blue interior installed to replace their nice black Si interior
Maybe he's just giving you a Si motor... in a HF/DX body.
What does it say on the engine block?
D15B6 or D16A6
Does it have the Si badge?
Also you can run a free vin check on it and it will tell if it is a 1.5 or 1.6(for the car,...he might have done the swap)
Does the cluster have a tach in it?
In order to tell if it is a 88-89 or a 90-91, look around the cluster, is it square or rounded as it is molded into the dash?
Another thing with the tach....what does it redline at? HF tachs show the redline around 5k, while si tachs show 6500ish (I know the redline of the si motor is 6800, but yeah it's not exactly stock in my case so it's not like i really care what the stock redline is... (i usually wait until i hit the needle to the dash
all wheel discs are usually a giveaway, BUT a friend just got a 89 SI that yes, in fact was an SI ....but it had rear drums
. It had the badge, tach, moonroof, a6 motor, black interior etc....everything that a Si has....except it had rear drums.
anyways hope it helps
D15B6 or D16A6
)all wheel discs are usually a giveaway, BUT a friend just got a 89 SI that yes, in fact was an SI ....but it had rear drums
. It had the badge, tach, moonroof, a6 motor, black interior etc....everything that a Si has....except it had rear drums. anyways hope it helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T »</TD></TR><TR><TD CLASS="quote">my 88 si has rear drums as well</TD></TR></TABLE>
88-89 CRX Si's had drums
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T »</TD></TR><TR><TD CLASS="quote">Ya I really wanna switch over to some stock Si rear disks, is it really really difficult, I dont know much about the brake system at all</TD></TR></TABLE>
leave it as is...
brakes are nothing to **** with especially if you dont know what you're doing
There are 2 things you must never half *** when it comes to cars... brakes and suspension. You can half *** your power supply / motor etc all you want becuase it isn't going to kill ya...****** w/ brakes + suspesnion and not doing it right will kill ya.
leave it as is...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T »</TD></TR><TR><TD CLASS="quote">lol Id obviously be researching before I jump in
Most Ive ever done brake wise was change pads, even that wasnt fun</TD></TR></TABLE>
Yeah of course....but I was just trying to say it is something that shouldn't be done by a clueless person. If you do the research and all that and are confident that you can do it and want to shell out the extra money then by all means do it. I know you're up there in canada and even here in wisconsin I hear bad things about rear disc brakes in the snow....
I've had 2 si's that had rear disc brakes and with both there was a problem with the rear drivers side brake caliper... and I've had 2 88's (1 4dr and 1 crx) and the drums work great for burnouts
OT: How are the rods working for you?
Rods are actually being installed today, UPS guy should be at my door anytime now with my bearings/gasket kit
Motor is completely built to **** now, 300whp d16 isnt gonna be a problem as soon as Hotrex sends me my 3" dp and ramhorn mani
I know all the differences between the si and dx/hf but it just seemed wierd that it has an a6 in it. I know its mpfi too. I did however forget to ask about the sunroof, which now i feel really dumb becuz i should have known that.
Thanks guys
Thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T »</TD></TR><TR><TD CLASS="quote">Rods are actually being installed today, UPS guy should be at my door anytime now with my bearings/gasket kit
Motor is completely built to **** now, 300whp d16 isnt gonna be a problem as soon as Hotrex sends me my 3" dp and ramhorn mani</TD></TR></TABLE>
Good luck with hotrex.
Have you done any head work or is it a completely stock head? \
d<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 »</TD></TR><TR><TD CLASS="quote">I know all the differences between the si and dx/hf but it just seemed wierd that it has an a6 in it. I know its mpfi too. I did however forget to ask about the sunroof, which now i feel really dumb becuz i should have known that.
Thanks guys</TD></TR></TABLE>
So is it a sweet si or just a dx?
Its a dx, but its going obd1 with built LSv turbo in the next couple months. I already have the drivetrain that i pulled out my crvtec turbo rex.
Hopefully ill bring it to N11, If there even is one, which i hope there is.
Mr. Thunderlips
48
Mar 5, 2012 06:47 AM
crxcess
Aug 19, 2005 03:09 PM
manson
14
Jul 15, 2003 08:01 PM
