Camber Adjustment... How many degrees is recommended?
Old Feb 9, 2005 | 12:55 AM
BuBBa y0!'s Avatar
Default Camber Adjustment... How many degrees is recommended?
I'm about to order adjustable ball joints, but having a dilemma on which ones to order. There are 2 different ones i could choose from in which how many degrees could be adjusted:
-1.50° to +1.50°
+1.50° to +3.00°
Which one is needed? Please help!
Thanks!
Old Feb 9, 2005 | 08:19 AM
b18cx's Avatar
Default Re: Camber Adjustment... How many degrees is recommended? (Bubba55)
For what application? Track car, street/ track car, or street car?
Old Feb 9, 2005 | 09:38 AM
BuBBa y0!'s Avatar
Default Re: Camber Adjustment... How many degrees is recommended? (b18cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cx &raquo;</TD></TR><TR><TD CLASS="quote">For what application? Track car, street/ track car, or street car?</TD></TR></TABLE>
whoops, i apologize It's going to be a SPFWD car... so a street/track car
Old Feb 9, 2005 | 02:38 PM
allm0t0rsir's Avatar
track/street car
Old Feb 10, 2005 | 01:07 AM
Default Re: Camber Adjustment... How many degrees is recommended? (allm0t0rsir)
bump
would like to know also
Old Feb 10, 2005 | 07:05 AM
93LSivic's Avatar
Depends on slick size and suspension travel. When the car lifts at the line it wants to be at 0 degress camber. If you can bolt your slicks on and then put the car approximately where it is after leaving the tree then thats the adjustment range you want.
Old Feb 10, 2005 | 08:59 AM
BuBBa y0!'s Avatar
Default Re: Camber Adjustment... How many degrees is recommended? (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">Depends on slick size and suspension travel. When the car lifts at the line it wants to be at 0 degress camber. If you can bolt your slicks on and then put the car approximately where it is after leaving the tree then thats the adjustment range you want.</TD></TR></TABLE>
so, if it wants to be at 0 degrees camber... i wouldn't need anything from the range of +1.50° to +3.00°, correct?
Old Feb 11, 2005 | 10:47 AM
BuBBa y0!'s Avatar
updog
i know i'm not the only one who wants to know this
Old Feb 11, 2005 | 01:05 PM
Kwuaymaikrup's Avatar
This taken from an old post by Tony1..this is how I will set up my car when the time comes.. Not sure if it is what you are looking for but it is good info none the less.
"Positive caster is a good thing in a race car, but you can't really do it on a honda w/o some pretty major modifications to the suspension. You should run a little negative camber, maybe .5 deg. or so, so that when the front lifts the camber is straight. I would also recommend 1/8" of toe in to help keep the car straight. If it still doesn't hook or go staight then the problem lies elsewhere..."
Old Feb 11, 2005 | 01:32 PM
BuBBa y0!'s Avatar
Default Re: Camber Adjustment... How many degrees is recommended? (Kwuaymaikrup)
thanks!
rrcipolla
Suspension & Brakes
Aug 3, 2008 06:01 PM
atc5
23
Jan 4, 2006 04:41 PM
Booker
48
Nov 15, 2005 07:30 AM
slowr6
19
Jul 15, 2004 02:23 PM
