crx broke down. possible timing belt slip?
Old Feb 8, 2005 | 10:39 PM
b16acrxer's Avatar
Default crx broke down. possible timing belt slip?
crx has a b16a. i was pulling out of a parking lot when i noticed my car felt really weak. i drove about a mile and the car felt weaker and weaker, so i pulled over, popped the hood. i heard a bit of clanking from the head. so i turned the motor off, checked around and didnt see anything (this was night time..) tried to start the car again, and it wouldnt start.
the next day when it was a little brighter i took a look at the timing belt... its not broke, but on the backside of it theres a little chunk missing in one spot, which leads me to believe the belt may have skipped a tooth or 2, since that area of the belt is probably a little more stretchable than usual, for lack of a better word.
im hoping i will be able to put a new belt on and reset the timing and go on my marry way.
any sageful advice is well appreciated.
thanks.
Old Feb 8, 2005 | 10:42 PM
crxnj's Avatar
Default Re: crx broke down. possible timing belt slip? (b16acrxer)
Old Feb 8, 2005 | 10:48 PM
b16acrxer's Avatar
Default Re: crx broke down. possible timing belt slip? (Mr.speaker)
u didnt say anything....lol
Old Feb 9, 2005 | 12:10 AM
96-EJ6 B18C's Avatar
Spin it over to TDC on #1 and all the timing marks should line up...if they don't then you'll know that it slipped.
Throw a new belt on it and do a compression test.
Best of luck
Old Feb 14, 2005 | 08:40 PM
b16acrxer's Avatar
Default Re: crx broke down. possible timing belt slip? (96-EJ6 B18C)
reset timing, new belt, compression test, its fixed. im glad it didnt break. thanks yall.
Old Feb 15, 2005 | 11:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16acrxer &raquo;</TD></TR><TR><TD CLASS="quote">reset timing, new belt, compression test, its fixed. im glad it didnt break. thanks yall.</TD></TR></TABLE>
Good to hear!
doc500
Apr 13, 2012 05:52 PM
jakop92
Aug 31, 2008 07:21 AM
EFin' Kyle
12
Apr 28, 2006 09:07 PM
TODA GS_R
Nov 14, 2005 01:04 PM
GSRaCeRbOI
Oct 22, 2002 06:34 PM
