Replacing rear speaker grille on 92 Lude
Old Feb 8, 2005 | 10:26 PM
txl146's Avatar
Default Replacing rear speaker grille on 92 Lude
I am thinking about replacing old and faded rear speaker grille with fancy aftermarket ones. Would aftermarket grille fit in place of old grilled without any fitment issue? Crutchfield recommends to use stock grilled... any thought on this?
Old Feb 9, 2005 | 03:51 AM
chandler's Avatar
cant you just paint the stock ones?
Old Feb 9, 2005 | 05:11 AM
five-0's Avatar
Default Re: (chandler)
OMG. I haven't had stock grills for so long that I forgot how nasty they are! EEEWWWW. I used aftermarket ones and they fit fine. They were even the cheapies from Pepboys. It's just a plain black grill. It's more of a press fit than anything. If you have a brain.... you can make it work.
Old Feb 9, 2005 | 05:40 AM
kulrevon's Avatar
Default Re: (five-0)
I have infinity kappas with the infinity speaker covers. They fit on the deck fine and bolt up stock.
Old Feb 9, 2005 | 06:27 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">I have infinity kappas with the infinity speaker covers. They fit on the deck fine and bolt up stock. </TD></TR></TABLE>
link/pics of said speakers/grills? I need to replace the speakers in my prelude, that thing rattles too much.
Old Feb 9, 2005 | 06:29 AM
txl146's Avatar
Default Re: (Sticky Tires)
so consensus is that any aftermarket grille will fit without any problem.
Old Feb 9, 2005 | 06:33 AM
* B A N N E D *
Default Re: (txl146)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by txl146 &raquo;</TD></TR><TR><TD CLASS="quote">so consensus is that any aftermarket grille will fit without any problem. </TD></TR></TABLE>
not any, you have to do some research/measurements. some will fit perfectly, some will require customization.
Crutchfield should have a list of what fits.
Old Feb 9, 2005 | 07:07 AM
AndyD's Avatar
Default Re: Replacing rear speaker grille on 92 Lude (txl146)
I used Ritt cloth dye. I just dyed the carpet on the door panels. I used detergent and it caused the carpet to fade. However, the dye made it look nice. Nice and black again.
I am going to dye the rear speaker grills too. I've done them before. I didn't mix salt in the mixture though. Hopefully, they will stay black longer than they did last time.
Old Feb 10, 2005 | 02:25 PM
shl76's Avatar
Default Re: Replacing rear speaker grille on 92 Lude (AndyD)
just remember that the rear spkr housing and grille are not perfectly flat. there are countours to accomodate the slight slope of the rear deck. thus, not all aftermarket grilles will fit.
i just took my stock grilles and painted them w/ a light coat of black spray paint. it sounded like a ghetto idea at first but it worked great.
Old Feb 10, 2005 | 02:42 PM
NZludedude's Avatar
Can some of you guys list the size and brand of after market speakers you have in your door pods and parcel tray, because there isn't alot of room in there. for axample dose any one have 6x9 in there car.
Old Feb 10, 2005 | 04:06 PM
The Phil's Avatar
Default Re: (NZludedude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NZludedude &raquo;</TD></TR><TR><TD CLASS="quote">Can some of you guys list the size and brand of after market speakers you have in your door pods and parcel tray, because there isn't alot of room in there. for axample dose any one have 6x9 in there car.</TD></TR></TABLE>
shouldn't you make another thread for this? kinda not on topic...
stock door speakers are 6.5" on 4th gens. Without changing a bunch of **** around you cant fit anything else.
johnwiltfongjr
Mar 30, 2006 03:32 AM
spooncivic1
16
Apr 3, 2005 01:44 PM
bleebdat
May 20, 2004 10:13 AM
dcrbin22
Audio / Security / Video
May 18, 2004 05:08 AM
