differences
Old Feb 8, 2005 | 09:26 PM
who.needs.torque's Avatar
Default differences
whats the difference between cable and hydro transmission and which one does the crx have? and same for the obd is it 1 or 0 and are they hard to convert if you want to do a ls/vtec and a gsr transmission
Old Feb 8, 2005 | 09:31 PM
crxnj's Avatar
Default Re: differences (who.needs.torque)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by who.needs.torque &raquo;</TD></TR><TR><TD CLASS="quote">whats the difference between cable and hydro transmission and which one does the crx have? and same for the obd is it 1 or 0 and are they hard to convert if you want to do a ls/vtec and a gsr transmission</TD></TR></TABLE>
Crx has cable tranny..
And the crx has pre-0bd(obd0)
You can do an lsvtec with a obd0 head..And you can get a 92-93 gsr tranny..Its cable...
There are kits to convert the car to hydro tranny..Hasport.com
And there are obd0-0bd1 conversion harnesses to convert the car's wiring..Blown90hatch sells the best harnesses..And droppedcrxsi
Old Feb 9, 2005 | 03:15 PM
Default Re: differences (Mr.speaker)
ok thanks, how much extra you think that would cost??
Old Feb 9, 2005 | 03:30 PM
ssl2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">
And there are obd0-0bd1 conversion harnesses to convert the car's wiring..Blown90hatch sells the best harnesses..And droppedcrxsi</TD></TR></TABLE>
I'm doing a ls/vtec with a 98 GSR head (obd2) into my CRX. While yes, I can run it obd0 (just need the dist and ecu) I"m converting it up ot obd1 becuasE I'll be boosting it and want to rub uberdata. YOu can get several cable b series trannys or get the kit either way you're good to go, hydro's are suppose to be stronger so it's up to how much you want to spend.
If you can, stay away from LS trannys = there gear ratios are "teh suck".
Old Feb 9, 2005 | 05:14 PM
Rywire's Avatar
Default Re: differences (ssl2k)
If you need any wiring modifications, let me know at http://www.rywire.com
Ryan
tomek5x
Dec 22, 2007 09:32 AM
thegreat0ne
Apr 10, 2007 10:31 PM
ilikejesus
Jan 9, 2007 07:48 PM
AWDspyder
Aug 10, 2005 05:06 PM
crazy eyez killa
Jan 26, 2004 03:02 PM
