B16 trannys.... Y1 or S1.... LSD?
hello all, just a quick question, I have reserved an engine at the local engine importer today and its got a S1 transmission and I wasn't sure if its the one with the LSD or not... they did not have anything listed about it. I looked in the side of the axle hole and there was a bar in there... is that the LSD? or would it be blocked all the way?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">Pop the axle out of the tranny
If you can see through the tranny then it has lsd..
If you can't it does <U>not</U> have lsd..</TD></TR></TABLE>
what he said..
s1's & j1's typically didnt have lsd's (but have the shortest gearing)
Ys1's came with lsd's typically (but not all) and had the same gearing as the above mentioned
Y1's came w/ lsd's sometimes but have slightly longer gearing than the others
what he said..
hondaZvic
Apr 24, 2006 12:27 PM
Nextelbuddy
Mar 31, 2003 07:40 PM
