would a jdm dc2 type r headers 4-1 work on a stock ls motor?
yea.. my homie has a stock ls motor.. and i was wondering if the jdm DC2 type R headers 4-1 would work? would it lose power ? or anything?
from what i heard it will fit but it wont bolt up to your stock cat, you'd need a test pipe or high flow cat but can someone confirm, this is just what i found when i searched it
the jdm header has a 2.5 inch collecter so that will not match up to the stock ls cat. but the header will bolt on to the head. stock the ls head doesn't flow enough to take advantage of the header. he will probably lose power, most likely in the mid range.
