90 CRX wont start....
Old Feb 8, 2005 | 07:32 PM
B18C1 Civic EG's Avatar
Default 90 CRX wont start....
ok, so i have a 1990 crx that i been working on that is having some problems. i had the head on it rebuild and resurfaced, put everything back together, car started up. 2 days later. car wont start anymore. so i change to dissy cap and rotor, still nothing, i change the ign. coil. still nothing. car has no spark. so then i check the fuel, and there is no fuel pressure either. whats going on. im not real familiar with OBD-0. someone told me that the light on the ecu should flash when the ignition is turned on, but its not doing anything. any advice?
Old Feb 8, 2005 | 07:33 PM
untitled's Avatar
Default Re: 90 CRX wont start.... (B18C1 Civic EG)
im first,
ECU fuse is blown, garuntee it... or the ecu itself went bad.
Old Feb 8, 2005 | 07:35 PM
ssl2k's Avatar
Default Re: 90 CRX wont start.... (untitled)
Well I guess I'm second...
Is the light blinking at all? is it soild?
I think untitled gets the cookie for this question. +1
Old Feb 8, 2005 | 07:44 PM
i checked all the fuses in the engine compartment, and there all good. then i tried changing the ecu with another. i think the car had a pm6 or something like that, and i tried a pr4. its a crx si. and there was still no light, no blinking light, no solid light, nothing. so i dunno. where would the ecu fuse be located on this car?
Old Feb 8, 2005 | 07:45 PM
untitled's Avatar
the 15amp should be blown...
if not check your main realy, swap it out with one that works. The main relay controls fuel and spark power.
Old Feb 8, 2005 | 07:46 PM
where is the main relay? what does it look like?
Old Feb 8, 2005 | 07:50 PM
untitled's Avatar
its under the driver side dash...
seriously youll get way more info faster if you just run a quick search, youll get photos and all info how to fix it.
You can resolder if its broke or cracked, it will be in a rectangle box and bolted to the car by one 10mm nut, its a bitch to get too, so after you get to it, leave it unbolted but tucked away.
Old Feb 8, 2005 | 07:53 PM
alright. thanks for the help. hope this is the problem.
Old Feb 8, 2005 | 07:56 PM
untitled's Avatar
with cars ive came up with this saying
Hope for the best, Expect the worst.
Good Luck
whitecrx
Jul 9, 2007 03:11 PM
red civic standard
Aug 9, 2006 03:50 PM
h22_crx
Mar 19, 2006 12:50 PM
cliffjumpercrx
Jun 20, 2005 03:48 AM
AgentJam
17
Aug 27, 2003 06:54 PM
