QUestion about DIY manifold
Old Feb 8, 2005 | 07:06 PM
juicedse's Avatar
Default QUestion about DIY manifold
In this manifold, on runners 2 & 3. What size hole saw should be used to fishmouth the runners, when using 1.5" pipe?
Old Feb 8, 2005 | 07:07 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: QUestion about DIY manifold (juicedse)
why dont you just pm the guy who made it....
Old Feb 8, 2005 | 07:17 PM
philipwight's Avatar
to get the clean look that he did, measure the OD of the pipe you are working with and get that size hole saw
Old Feb 8, 2005 | 07:20 PM
Bailhatch's Avatar
Default Re: QUestion about DIY manifold (philipwight)
A hole saw/notcher cant make that cut perfectly becasue its on a bend. you could get it close by making 2 holesaw cuts, one from each side about 130* out, then grind to fit. Besides it might work slightly better if you dont make 2 and 3 come in at 90*.
Old Feb 8, 2005 | 09:03 PM
5STAR3's Avatar
Default Re: QUestion about DIY manifold (Bailhatch)
nm
AlfieRoach
Nov 25, 2010 11:00 AM
sbiggi
Welding / Fabrication
Feb 3, 2008 12:47 PM
.RTErnie
Dec 11, 2005 08:32 AM
Roky
Jan 11, 2004 02:32 PM
redboost10
Nov 24, 2003 01:58 PM
