Need help asap with lug nut
Old Feb 8, 2005 | 06:57 PM
DOHClessEF-9's Avatar
Default Need help asap with lug nut
ok heres the problem i got a 00 civic coupe dx, one lug nut on the right drivers side doesnt want to come off, i think it is that the stud is stripped from the inside, but heres the question does anyone know on how I could get if off, I really need help!!!
Old Feb 8, 2005 | 07:00 PM
Street Ghost's Avatar
Default Re: Need help asap with lug nut (pnoyra5er808)
does it just spin when u try to take it off? if it does.. it could be possible that the entire lug stud stripped itself off the hub.
if thats the case.. you will probably need to do some kind of drilling the get the lug nut off, then replace the lug stud.
Old Feb 8, 2005 | 07:05 PM
green-'s Avatar
Default Re: Need help asap with lug nut (_Edge.ONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Edge.ONE &raquo;</TD></TR><TR><TD CLASS="quote">does it just spin when u try to take it off? if it does.. it could be possible that the entire lug stud stripped itself off the hub.
if thats the case.. you will probably need to do some kind of drilling the get the lug nut off, then replace the lug stud.</TD></TR></TABLE>
I was thinking the same.
This happened to me once. I didnt do any drilling, but I tried so many different things. Air tools, hammer, vice grips, etc...It took like 2 hours to get off but it came off. Lug nut was shot and stud had to be replaced.
Old Feb 8, 2005 | 08:04 PM
Default Re: Need help asap with lug nut (green00EX)
need help
laocivic
Feb 5, 2008 07:43 PM
importboi22
Sep 25, 2006 04:44 PM
inty2511
May 28, 2003 05:53 AM
BrandonClaps
Aug 29, 2002 08:50 PM
