OBD0 to OBD1 help
Old Feb 8, 2005 | 06:39 PM
CRX_Type_R's Avatar
Default OBD0 to OBD1 help
I tried searching but found a lot of different answers.
What do I need to convert my D16Z6 powered '91 CRX Si to OBD1?
I need a complete list.
Old Feb 8, 2005 | 06:41 PM
ssl2k's Avatar
Default Re: OBD0 to OBD1 help (CRX_Type_R)
arg...
You're going to need the conversion harness, either make yer own, or buy one there is one for $59 and then another for $74...look at the banners
obd1 ecu (p28)
wire
solder + solder gun
obd1 dist
stock z6 or y8 intake manifold
4 wire o2 sensor
you'll need ot add another bung to the exhaust
Old Feb 8, 2005 | 06:42 PM
EP3_05's Avatar
OBD1 distributor
OBD1 ecu
4 wire heated oxygen sensor
OBD0-OBD1 conversion harness
Most people will tell you to search but I am in a helping mood so there ya go.
Old Feb 8, 2005 | 06:43 PM
untitled's Avatar
Default Re: OBD0 to OBD1 help (ssl2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssl2k &raquo;</TD></TR><TR><TD CLASS="quote">arg...
obd1 ecu (p28)
wire
solder + solder gun
obd1 dist
4 wire o2 sensor
you'll need ot add another bung to the exhaust </TD></TR></TABLE>
i feel your "arg", we just done this 20 mins ago.
You wont need the intake mani if you bought the engine. Also you will need to either use obd1 injectors and take you resistor box out OR use the obd0 injectors and keep the resistor box in.
Old Feb 8, 2005 | 06:48 PM
krazie1's Avatar
BANNED
Default Re: OBD0 to OBD1 help (untitled)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untitled &raquo;</TD></TR><TR><TD CLASS="quote">
You wont need the intake mani if you bought the engine. Also you will need to either use obd1 injectors and take you resistor box out OR use the obd0 injectors and keep the resistor box in.</TD></TR></TABLE>
correct-o mundo the right answer and help in case the engine is already
aXhatch
Sep 12, 2006 06:26 PM
teggytegteg
Apr 16, 2006 12:11 AM
Ls On StErIoDs
Sep 12, 2005 09:04 PM
7rrivera7
Nov 9, 2002 06:38 AM
h46it
Jun 18, 2002 05:23 PM
