WHAT PARTS FOR THE EG????
I would like some help from the experts!
I own a DA and know tons of **** about DAs most of the stuff I know is for tegs
but when it comes to the eg I have no clue on what parts fits what etc...
I just got a 1994 hb dx
I want to upgrade the following:
Suspension
brakes
axles
cluster
side skirts
strut bars
sway bars
seats!
Which parts from other cars fit the eg best?
do DA parts fit the eg? I know most of the dc2 parts fit the eg!
what side skirts fit the eg.
Any help would be appreciated and will hopefully help others with the same questions
also what do you guys recommend for the eg as far as any mods!
pics would be nice I'm looking for outside, inside and engine mods!
I was thinking about trowing my DA seats on the eg but I don't know if they fit!
Thanks
Suspension
brakes
axles
cluster
side skirts
strut bars
sway bars
seats!
Thanks
thanks bro!
If you guys know of any other links I can use it would be great!
When I searched I noticed that most of the type the threads have different names than the ones I type even tho is the same inf.
So any more links would be great
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1024818</TD></TR></TABLE>
Thats pretty much the whole shebang right there. Your post is pretty vague on which parts specifically. If you can't find it in there, try to search it individually.
All of these rear disks will work on the 92-00 Civics.
-First off, the 5 lug ITR setup. We all know this works.
-Then there is the JDM 4x114.3 setup off of the ITR before it came to the states.
-All of the Integra rear disks are the same for the 3rd gen, so any of the 3rd gen (DC) brakes will work.
-Rear trailing arm with hub assembly for disk brakes (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00)
-Upper control arm (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00)
-Compensator arms at the front end of the trailing arm (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00)
-Rotors (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00)
-Brake calipers and brackets (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00)
-Brake pads with shims (get the genuine honda ones) (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00)
-Parking brake cables (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00)
-Brake Booster (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00)
-Master cylinder (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00, 91 civic ex)
and that was the first post of https://honda-tech.com/zerothread?id=1024818
I need to know if the da stearing wheel works on the eg
the seats as well
I have a 92 Da
I want to swap any parts I can into the eg besides the engine which is the 1st thing I'll do
any help or links are great thanks
the seats as well
I have a 92 Da
