ACT clutch question on B18C5 with 100 shot of NOS
Old Jan 16, 2002 | 10:56 AM
MUGENTYPER's Avatar
Default ACT clutch question on B18C5 with 100 shot of NOS
wassup people!! im in a process to order a ACT clutch right now just wanted to know if i need the 6 puck disc or 4 puck disc i should buy... i have NOS installed on my car and just wanna make sure if u guys r using the same.. please give me some info about what you guys are using!! thanks
Old Jan 16, 2002 | 11:02 AM
976's Avatar
976
New User
Default Re: ACT clutch question on B18C5 with 100 shot of NOS (MUGENTYPER)
What engine are you running? 4 puck should do the job find, from what I've learned 6 puck is almost overkill. NOS doesn't matter, just learn to let clutch out fast enough so you're not engaging while shooting up...
Old Jan 16, 2002 | 11:10 AM
Knightsport's Avatar
El Chico
25 Year Member
Community Builder
Community Influencer
Default Re: ACT clutch question on B18C5 with 100 shot of NOS (B21A)
The 6-puck is hard on the synchors and tranny overall. There's no need to use the 6-puck with your application.
Old Jan 16, 2002 | 11:20 AM
MrBite's Avatar
I thought the fewer the # of pucks, the more agressive since there's less area for the same amount of pressure? I would think that 6 would be enough, 4 would be overkill. or am I backwards...?
Old Jan 16, 2002 | 11:38 AM
Crazydave's Avatar
Default Re: ACT clutch question on B18C5 with 100 shot of NOS (MrBite)
I hate my 6 puck... But I've never driven with a 4 puck..
only the 6 puck and the stock clutch.....
It chatters BAD
Old Jan 16, 2002 | 12:29 PM
El Chico
25 Year Member
Community Builder
I was almost certain it was the other way around too. But when in Rome.
Old Jan 16, 2002 | 11:51 PM
PyroVTEC's Avatar
New User
Default Re: ACT clutch question on B18C5 with 100 shot of NOS (Knightsport)
4-puck is more harsh than a 6-puck.
Old Jan 17, 2002 | 04:13 PM
Kataku2K3's Avatar
Default Re: ACT clutch question on B18C5 with 100 shot of NOS (PyroVTEC)
Yea 4 puck will chatter more then a 6 puck and is better for all motor high rpm shifting because it has less rotational mass. I would just go with the 6-puck. Oh also what pressure plate did you get the heavy duty or Xtreme?
Old Jan 17, 2002 | 07:37 PM
B_CRUZ!'s Avatar
Default Re: ACT clutch question on B18C5 with 100 shot of NOS (JDMspecEG6)
4 puck is a tranny killer. it out lasted 4 of my D16A trannies in my old rex. before i switch to a stock clutch the act blew my differential out. it grabs hard though.
Old Jan 17, 2002 | 07:55 PM
MUGENTYPER's Avatar
well im still choosing on which one i will buy... u said 6 puck?? do u have the same set up that i have?
Old Jan 18, 2002 | 02:03 PM
SPEED123's Avatar
while you are thinking of buying a new clutch, you might wanna buy a new motor too....good luck.
Old Jan 18, 2002 | 02:13 PM
itr0045's Avatar
Default Re: ACT clutch question on B18C5 with 100 shot of NOS (SPEED123)
A bigger clutch will wear your tranny out faster. You may even break an axle or two with one if you race it a lot. With NOS, you want to make sure you are not squeezing while you shift. I wouldn't power shift while you are squeezing with any clutch, stock or aftermarket. I am not sure how you have your NOS kit set up. Mine was on the horn, so I could let off between gears for a fraction of a second. Also, a key to bigger clutches is not to downshift hard. Meaning, don't be doing 70 on the freeway and shove the car into third as you dump the clutch. That will TOAST your gears in a hurry.
X2BOARD
Feb 26, 2005 03:45 PM
98ITR#0020
Jul 2, 2004 09:14 AM
4thgenlude
May 12, 2004 08:25 PM
MUGENTYPER
Jan 18, 2002 11:46 AM
MUGENTYPER
Jan 16, 2002 12:39 PM
