jdm sidemarkers ????????????
Old Feb 8, 2005 | 01:07 PM
SPOONup's Avatar
Default jdm sidemarkers ????????????
Those of you in the SoCal area .. where did you get your sidemarkers installed?
I do not want to attempt this job on my own, though i normally do my own work .. I just got the teg painted and dont want to ruin my fenders or crack the paint. Also what kind of wiring do i need to purchase .. it looks like a plug in the back of the sidmarker .. not so sure what i need to hook these up correctly .. i want them to stay on when i turn my lights on and blink with the blinker as well Thanks and yes i searched
Old Feb 8, 2005 | 01:20 PM
97dc2's Avatar
Default Re: jdm sidemarkers ???????????? (SPOONup)
You should do it yourself. I did my own last week and it came out really good. I used regular speaker wire for the wiring and female plugs for the connectors.
Old Feb 8, 2005 | 01:26 PM
dFreezy's Avatar
Default Re: jdm sidemarkers ???????????? (97dc2)
i just did mine this weekend with my brother. the only items you need for the wiring is basic speaker/power wires (i used 18 guage), quick connect wire taps (4 of them), and female spade connectors (4 of them). they turned out looking ok, although the metal nibbler left the surface of the fender slightly 'warped' at the hole we cut so upon close inspection you can see the sidemarker doesnt sit completely flush with the surface (but damn close)
Old Feb 8, 2005 | 01:39 PM
Taristin's Avatar
I think your '?' button is a little sticky.
Old Feb 8, 2005 | 02:19 PM
integraXTC's Avatar
do those have reflectors in them?
Old Feb 8, 2005 | 02:21 PM
Vtecfool's Avatar
Default Re: (integraXTC)
kinda want some side markers on my car too, but i'm scared i'll f*ck up.
Old Feb 8, 2005 | 02:22 PM
uzabatty's Avatar
gotta get me some
Old Feb 8, 2005 | 02:32 PM
hi mom's Avatar
Default Re: (Vtecfool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecfool &raquo;</TD></TR><TR><TD CLASS="quote">kinda want some side markers on my car too, but i'm scared i'll f*ck up.</TD></TR></TABLE>
my exact thoughts
to finish my si-vtec "conversion", thats all I have left
just not confident in cutting holes in my fenders
Old Feb 8, 2005 | 02:39 PM
virusiidx's Avatar
i did mine a few months ago, just get the right tools or you'll risk messing something up. also tape up around it just in case.
Old Feb 12, 2005 | 07:57 AM
94vtecteg's Avatar
before i put the jdm front on , they were on my 94 front . me and a friend put em on and we used a drill, and a dremel. scary but it works!
Old Feb 12, 2005 | 10:10 AM
Avenged7x's Avatar
Default Re: (94vtecteg)
well i think his original question was a place to install it for him, being he doesnt want to do it himself. so can any1 actually help him out?
Old Feb 12, 2005 | 11:03 AM
dFreezy's Avatar
Default Re: (Avenged7x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Avenged7x &raquo;</TD></TR><TR><TD CLASS="quote">well i think his original question was a place to install it for him, being he doesnt want to do it himself. so can any1 actually help him out? </TD></TR></TABLE>the question was answered. most people did themselves. if you're unsure about your ability to do it, you should just take it to any local body shop. a final option would be to buy the si-vtec fenders from passwordjdm.com, but then you'd have to get them painted and/or have any dents smoothed out.
Old Feb 12, 2005 | 11:12 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (dFreezy)
I used this diagram:
Then I drew the shape of the cutout in AutoCAD using those dimensions, to make sure that it would print out the exact size. Then I located the placement where the hole needed to be on the BACKside of my fenders, taped the paper in place, and then scored lines in the metal using a small straightedge and an Xacto knife. Then I drilled a hole large enough for my metal nibbler, used tape on the outside of the fender, and cut out the hole. When using the metal nibbler, I had the handles on the painted outside of the fender (with the tape protecting that area) and the head of the nibbler stuck through to the backside of the fenders. That way I was able to precisely follow the scored lines I had made with the cutting head of the nibbler.
Oh yes and I did have the fenders off the car for this process.
Old Feb 12, 2005 | 12:03 PM
Xsi's Avatar
Xsi
Thats a great diagram
This page may help if you have a g2: http://www.integra.orcon.net.nz/indicator.htm
Old Feb 12, 2005 | 12:06 PM
pearlteg's Avatar
Default Re: (Xsi)
if you want it done professionally i did mine at m1autobody in el monte . they did mine with the same setup u want on when your parking light are on and blink
Old Feb 12, 2005 | 01:01 PM
Dc2 Powered's Avatar
PM'd
Old Feb 12, 2005 | 05:06 PM
SPOONup's Avatar
Default Re: (Dc2 Powered)
thanks alot guys
mikemayer99
Acura TSX
Apr 6, 2009 02:33 PM
yellowdcn
Aug 15, 2007 09:38 AM
mattcivic
Jun 18, 2005 11:30 AM
SPOONup
Feb 12, 2005 08:38 AM
tC_Dragon
Nov 15, 2002 11:40 AM
