Install JDM sidemarkers?
Those of you in the SoCal area .. where did you get your sidemarkers installed?
I do not want to attempt this job on my own, though i normally do my own work .. I just got the teg painted and dont want to ruin my fenders or crack the paint. Also what kind of wiring do i need to purchase .. it looks like a plug in the back of the sidmarker .. not so sure what i need to hook these up correctly .. i want them to stay on when i turn my lights on and blink with the blinker as well
Thanks and yes i searched
r u plannin on puttin these on the usdm fenders?...well if anybody knows the wire diagram to make the sidemarkers stays on when u turn on the lights and blinks also...i wanna know too...because mines stays on all the time and it doesn't blinks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 »</TD></TR><TR><TD CLASS="quote">Just wire it together with the front corners. Parallel, + to +, - to -</TD></TR></TABLE>
Shouldn't they be wired only to the turn signal? Or do Honda sidemarkers stay on all the time. I know my OEM sides only flash with the turn signal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat »</TD></TR><TR><TD CLASS="quote">
Shouldn't they be wired only to the turn signal? Or do Honda sidemarkers stay on all the time. I know my OEM sides only flash with the turn signal.</TD></TR></TABLE>
Which bulb flashes in the front corners with the turn signal? That one. Or is that always on in an USDM ITR?
We have 2 bulbs in the front corner light. 1 is white, which is the city light. The other one is amber and flashes with turn signal.
Usually any body shop would be able to install them for you. As for the wiring...you gotta sorta figure that out yourself man
If the bulb is double filament (should be) then you should be able to have them stay on and blink when you flip on the turn signals.
I hate wiring...
I hate wiring...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by {Mineral Grey} ITR »</TD></TR><TR><TD CLASS="quote">It might be expensive....but Try SuperAutobacs in Stanton.</TD></TR></TABLE>
Probably even more expensive @_@
KRZRICAN
Feb 4, 2009 07:51 AM
Drinker
