problem with brakes.
Old Feb 8, 2005 | 12:01 PM
dropt's Avatar
Default problem with brakes.
Car was sitting for a bit, go to get it back on the road and now the brakes are all messed up. They are really soft until the last inch or so of pedal then stiffen up and work. I can drive but I dont think its *that* safe? I tried bleading the brakes and got no results. Would this be the brake booster or mast cyl. causing the problem?
THanks guyS
Old Feb 8, 2005 | 11:30 PM
iand415's Avatar
Default Re: problem with brakes. (dropt)
how are your pads? low pedal feel could be caused by your brake pads also. it could be your master cylinder too
Old Feb 9, 2005 | 04:33 AM
HYB90RID's Avatar
probably master cyl same thing happen to me was pretty scary specially with people in the car
Old Feb 9, 2005 | 04:52 AM
Turbowa's Avatar
You said that the car was sitting for a long time. Check your brake pads and rotors. If there was a lot of rust build up on the rotors the it would have transfered into the brake pad. This is why your pedal feels bad. Try changing out the front rotors and brake pads first. If it were your master cyl. you would have to pump the pedal to get any feel, not to mention bleeding them would have been almost impossible.
Kennyjai
Nov 28, 2012 12:00 PM
SiR Inspired ED7
Suspension & Brakes
Feb 24, 2010 03:31 PM
95sivee
Jul 10, 2006 07:59 PM
beyondspexj
12
Jan 7, 2006 06:16 PM
djay86
16
Sep 20, 2002 11:53 AM
