8 pin connector on distributor stuck
Old Feb 8, 2005 | 10:20 AM
vxnine's Avatar
Default 8 pin connector on distributor stuck
this the 8 pin connector on the distributor is stuck and no matter how hard i try to get it off its stuck. i would pry it with a screw driver but im scared that i might break the plastic. any suggestions?
Old Feb 8, 2005 | 10:21 AM
snatch's Avatar
Default Re: 8 pin connector on distributor stuck (frankcivic)
Though it may not be much help, I've had the exact same problem before. Can't remember what I had to get it off for, but I never did.
Old Feb 8, 2005 | 10:26 AM
SOHCejcivic's Avatar
Default Re: 8 pin connector on distributor stuck (******)
may sound kinda stupid but are you pulling on the right end? you might be pulling on the piece that's attached to the bracket.
Old Feb 8, 2005 | 11:03 AM
vxnine's Avatar
Default Re: 8 pin connector on distributor stuck (SOHCejcivic)
yes im pulling on the right one
Modified by frankcivic at 8:48 PM 2/8/2005
Old Feb 8, 2005 | 11:48 AM
vxnine's Avatar
bump for help
Old Feb 8, 2005 | 12:13 PM
STIBungy's Avatar
Easier to take it off the bracket and then unplug.
Old Feb 8, 2005 | 12:15 PM
SOHCD16y8's Avatar
Default Re: (STIBungy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STIBungy &raquo;</TD></TR><TR><TD CLASS="quote">Easier to take it off the bracket and then unplug.</TD></TR></TABLE>
yeah and once you get it off and its still not coming loose and you desparately need it then try to lightly pry on it
Rookiemistake
May 9, 2018 05:05 AM
Haleiwa-Brando
May 1, 2006 08:04 AM
B18C5er
Nov 15, 2004 05:20 PM
Frederz
May 8, 2004 09:18 AM
