Best CR for Buddy Club Spec 3+?
Which CR would be best for these cams in a b18c1, 11.6:1 or 12.0:1? Cant decide between p30 or ctr...this isnt a question about which pistons in paricular, because ive searched. no info directly relating to those cams tho
I am running an estimated around 11.3-11.6 and I dont think it was enough (260-265 psi all the way across)
I would go to 12:1 if I did it again
although I was running them in a 1.8l
I think it would depend alot on if you had an 84mm block
Beings that the specs are similar to cams such as skunk2 stage 1's, toda a's, etc. etc., the sweet spot for those cams is probably around 11.5:1. Any higher and you probably would start to undercam your motor.
red civic standard
Sep 28, 2004 01:51 PM
