HID kit for projectors
Old Feb 8, 2005 | 06:22 AM
onestopmb's Avatar
Default HID kit for projectors
Hey, i got a 92 civic with the projectors--> same seen here http://cgi.ebay.com/ebaymotors...33710
Can an h3 fog light HID kit work with this headlights. I want an 8000K on it.
I tryed doing a search but couldn't find it.
Thanks in advance
Old Feb 8, 2005 | 06:44 AM
Ricey McRicerton's Avatar
Default Re: HID kit for projectors (onestopmb)
8000k isn't going to be as bright as a 4300-4500k setup.
Old Feb 8, 2005 | 07:17 AM
albert's Avatar
Default Re: HID kit for projectors (Ricey McRicerton)
Yea they should work thats the correct bulb size for that headlight right?
I got 4300k there nice and bright!
Old Feb 8, 2005 | 08:00 AM
onestopmb's Avatar
I want them to look blue.
My cousin has a 8000k on his bmw and he has the projectors on them and i like the way they look.
I also heard that the H3 hid bulb might not fit inside the socket spot.
Does anyone have any pictures of there HID kid on projectors?
Thank you very much
Old Feb 8, 2005 | 08:09 AM
albert's Avatar
your going to need to do a retro fit using hid projectors. If you use the projector that comes with the headlights they will not look like your friend bmw since your friends bmw got hid projectors
heres my denji headlights which got projectors in them with hids you can see the glare http://pictures.sprintpcs.com/...azaNx I recomend you do a hid projector retro fit for the headlights,I'm going to do the same as soon as ?I get time
Old Feb 8, 2005 | 08:28 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: HID kit for projectors (albert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by albert &raquo;</TD></TR><TR><TD CLASS="quote">
heres my denji headlights which got projectors in them with hids you can see the glare http://pictures.sprintpcs.com/...azaNx I recomend you do a hid projector retro fit for the headlights,I'm going to do the same as soon as ?I get time</TD></TR></TABLE>
Do you have an H3 HID kit? Or do you have an OEM kit? If you have an OEM kit then the reason there is so much glair is because the gas chamber of the HID bulb is not in the place that the projector is designed to have it sit. AKA: the gas chamber is too far forward. Get some heat resistant washers and use as many as need be to make the gas chamber sit right where the bulge in the normal bulb sits in the projector. The cutoff/glare will be 100 times better that way.
Old Feb 8, 2005 | 08:42 AM
onestopmb's Avatar
Default Re: HID kit for projectors (Hatchy-Ownzjo0)
put washers where??
Old Feb 8, 2005 | 10:56 AM
albert's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 &raquo;</TD></TR><TR><TD CLASS="quote">
Do you have an H3 HID kit? Or do you have an OEM kit? If you have an OEM kit then the reason there is so much glair is because the gas chamber of the HID bulb is not in the place that the projector is designed to have it sit. AKA: the gas chamber is too far forward. Get some heat resistant washers and use as many as need be to make the gas chamber sit right where the bulge in the normal bulb sits in the projector. The cutoff/glare will be 100 times better that way.</TD></TR></TABLE>
yea this is a oem kit from maxima
lil kid
Honda Civic (2001 - 2005)
11
Aug 21, 2008 02:26 AM
matt21civ
Jul 24, 2006 05:29 AM
vexx7001
Oct 12, 2005 11:10 PM
AFAccord
Sep 22, 2005 10:14 AM
EX-JAY
Mar 19, 2005 07:50 PM
