will no speedo cable cause
Old Feb 8, 2005 | 05:31 AM
dirtracer's Avatar
Default will no speedo cable cause
My speedo cable broke at the speed sensor after a swap, Now the ecu sends out a code 17 which is the speed sencor;is that because the cable isn't there for the ecu to pick up the signal. The engine light doesn't come on till the car is up to temp. TIA.....89 Coupe
Old Feb 8, 2005 | 10:00 AM
dirtracer's Avatar
Default Re: will no speedo cable cause (dirtracer)
bump
Old Feb 8, 2005 | 02:53 PM
dirtracer's Avatar
Does no one know this ....how fast you're going
Modified by dirtracer at 5:00 AM 2/9/2005
Old Feb 9, 2005 | 06:14 AM
sj993's Avatar
Yeah probably. I would replace the cable and speed sensor if need be.
Old Feb 9, 2005 | 06:36 AM
dirtracer's Avatar
Default Re: will no speedo cable cause (sj993)
Thanks
89ED
Feb 26, 2018 10:47 AM
85mm LS VTEC
Apr 4, 2005 10:52 AM
jcrou
Dec 17, 2004 08:56 AM
ron b
Apr 29, 2004 10:49 AM
civicdragger818
Nov 8, 2002 07:02 AM
