FS: T3 turbo $125 shipped!!!
Old Feb 8, 2005 | 04:11 AM
Bird333's Avatar
Default FS: T3 turbo $125 shipped!!!
I got a T3 turbo for $125 shipped to the lower 48 states. There are no broken fins. It spins freely. There is NO in/out shaft play. If you try hard, there is LITERALLY 1mm side to side movement but from everything I have read this is the case even with new/rebuilt turbos. I take paypal (credit card is ok).
References
Ebay: gustavm
Heatware: Bird222
email me at dohcf22@gmail.com
Thanks!
Old Feb 8, 2005 | 04:46 AM
94exguy's Avatar
Default Re: FS: T3 turbo $125 shipped!!! (Bird333)
What are the trim and a/r sizes? Any chance of better pics? Thanks
-matt
Old Feb 9, 2005 | 04:47 PM
Bird333's Avatar
Default Re: FS: T3 turbo $125 shipped!!! (94exguy)
I can't find any spec numbers on the housing, so I took some measurements.
Turbine/downpipe opening is 2.5 inches (65mm) in diameter.
Compressor intake is 2.125 inches (54mm) in diameter.
Compressor outlet is 1.375 inches (35mm) in diameter.
Old Feb 10, 2005 | 12:42 AM
mitch-meister's Avatar
How much shipped to germany?
Old Feb 10, 2005 | 06:33 PM
Bird333's Avatar
Default Re: FS: T3 turbo $125 shipped!!! (mitch-meister)
Old Feb 11, 2005 | 06:47 AM
turboH22Aakkord's Avatar
i can tell with the pics there are some bent studs on the exhaust side? are the studs removable? how many studs are on the exhuast side? and .. is the turbo able to be clocked? thanks!!
Old Feb 11, 2005 | 07:06 PM
Bird333's Avatar
Default Re: FS: T3 turbo $125 shipped!!! (turboH22Aakkord)
Sure, I would imagine they could be removed. There are many ways to remove bolts/studs. There are 4 of them. If by clocked you mean the housing can be rotated, then yes it can.
Old Feb 12, 2005 | 11:27 AM
Bird333's Avatar
Old Feb 14, 2005 | 09:40 AM
Default Re: (Bird333)
no specs at all ??
Old Feb 14, 2005 | 01:27 PM
Bird333's Avatar
Default Re: (turboH22Aakkord)
I can't see anything that resembles specs on the housing. There are letter/number but they look like some manufacturing coding or something.
This is the last call before it goes to ebay.
Old Feb 14, 2005 | 01:55 PM
PaImportTuner's Avatar
is that the ford thunderbird t3 turbo?
Old Feb 14, 2005 | 03:56 PM
Bird333's Avatar
I honestly don't know. But I don't think so.
Old Feb 15, 2005 | 09:13 AM
Bird333's Avatar
Gone to ebay.
http://cgi.ebay.com/ebaymotors...52258
Old Feb 23, 2005 | 06:46 PM
screen_name's Avatar
im assuming its sold?
Old Feb 23, 2005 | 08:22 PM
Laserjock's Avatar
Default Re: (LB562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LB562 &raquo;</TD></TR><TR><TD CLASS="quote">im assuming its sold?</TD></TR></TABLE>
I'm hoping it's not. What's behind the Doc pepper can? Sure it's a 4 bolt and not a 5? Pics are kinda washed out.
****EDIT****
nm, i need to relearn how to read
backspin88
Dec 10, 2005 05:12 PM
MRturbo
Oct 18, 2005 06:47 PM
ScottFern
Jun 11, 2005 06:39 PM
