a/f ratio question
Old Feb 7, 2005 | 10:03 PM
sickerhatch's Avatar
Default a/f ratio question
ok i hooked up my wide band o2 sensor today,and its reading about 12 to one at idle and about 13 to 14 to one at wot.just wondering if these numbers look good.
Old Feb 7, 2005 | 10:10 PM
PrettyLude's Avatar
setup?
Old Feb 8, 2005 | 04:26 PM
Default Re: (PrettyLude)
the set up is
b16a
os ctr pistons
head milled
port -polish
ss valves
stock b16 cams
p28 with scunk2 program
i/h/e
b-m fpr
Old Feb 8, 2005 | 07:44 PM
Default Re: (sickerhatch)
bump
Old Feb 8, 2005 | 08:04 PM
IN VTEC's Avatar
Add on an AFC to work the AFR's to where they're supposed to be, or switch to Uberdata (or Hondata, but you have still have to add another component) since the ECU is already socketed.
What's the fuel pressure with the regulator's vacuum reference off?
Old Feb 8, 2005 | 08:06 PM
Default Re: (IN VTEC)
it set at 40 psi with vacume off
Old Feb 8, 2005 | 08:29 PM
IN VTEC's Avatar
Turn up the pressure up and trim down the idle and rich areas with an AFC.
cfourworld
Apr 16, 2010 07:42 AM
Lan
Jun 5, 2006 07:36 AM
92hybrid+
Sep 16, 2005 04:36 AM
Errol
Aug 17, 2004 07:34 PM
SCedGTP
Apr 10, 2003 11:54 AM
