what throttle body to go with??? im stumped
Old Feb 7, 2005 | 08:24 PM
majormaster01's Avatar
Default what throttle body to go with??? im stumped
I need to know what throttle body to get. My head has been completely rebuilt and is set to be an all motor high compression setup. I would say that I will be around 12:1 cr.. I am not sure what brand nor most importantly what size to go with. I want something that I can use stock sensors on and be a direct fit. any suggestions,let me know... thanks a lot
Old Feb 8, 2005 | 09:36 AM
Default Re: what throttle body to go with??? im stumped (majormaster01)
anybody???????????
Old Feb 8, 2005 | 09:45 AM
2point6's Avatar
I just recieved a supply of the New Skunk2 68mm throttle bodies. I reall like these. the machine work is nearly flawless. Contact me for pricing. They are cheap!
Old Feb 8, 2005 | 10:24 AM
Default Re: what throttle body to go with??? im stumped (2point6)
are they a direct bolt on with factory sensor locations? and how much??? my e-mail is dcarlson01@msn.com if you would like to e-mail me or call cell 315-945-0100. thanks
Old Feb 8, 2005 | 11:22 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by majormaster01 &raquo;</TD></TR><TR><TD CLASS="quote">I need to know what throttle body to get. My head has been completely rebuilt and is set to be an all motor high compression setup. I would say that I will be around 12:1 cr.. I am not sure what brand nor most importantly what size to go with. I want something that I can use stock sensors on and be a direct fit. any suggestions,let me know... thanks a lot </TD></TR></TABLE>
The throttle body size is typically based on displacement and wether or not it's NA or FI.
What's your displacement?
Old Feb 8, 2005 | 12:06 PM
Default Re: what throttle body to go with??? im stumped (skunked)
my motor is an ls/vtec. and it will be an n/a build. thanks for the help
Old Feb 8, 2005 | 12:50 PM
skunked's Avatar
So stock sleeve 1.8? If so I wouldn't go any larger than a 64mm. The JG is a good piece at a good price.
doubleecho
Jul 24, 2007 11:18 AM
ek_99_SiR
Jul 19, 2005 09:34 PM
eldorko86
Jul 17, 2005 07:19 PM
ssr_h22
Apr 23, 2005 07:53 AM
cjames235
Welding / Fabrication
Feb 3, 2005 05:36 PM
