head bolt reuse?
Old Feb 7, 2005 | 06:50 PM
d16efsedan's Avatar
Default head bolt reuse?
i have a blown headgasket and i was wondering if i could reuse the headbolts or do i have to order new ones?motor and head is a d16a6......
Old Feb 7, 2005 | 06:56 PM
dr_latino999's Avatar
Default Re: head bolt reuse? (d16efhatch)
It depends on how many times prior they were removed, it is though good to be on the safe side and order new ones, but I reused mine as they hadn't been removed since....ever.
Old Feb 7, 2005 | 07:00 PM
d16efsedan's Avatar
Default Re: head bolt reuse? (dr_latino999)
yeah i know i have never had the head off but not sure about the old owners........how much do headbolts usually cost?
Old Feb 7, 2005 | 07:04 PM
ZexCivic's Avatar
Do yourself and get some ARP headstuds. They will withstand a whole lot more abuse than the stockers and they are designed to be used over again. Plus they I think they are almost cheaper than buying new OEM ones from a dealer. I got my set for $120.
Old Feb 7, 2005 | 07:10 PM
davens's Avatar
If your budget is stretched they can be reused. Everybody says once. Some say twice. A handful will tell you they never needs replacing.
Last time I checked, a new OEM set would run like $80. The ARP set can be found for around $100.
Given that they can be reused and are a better design(stud vs bolt), the extra $20 is easily worth it.
Pair the studs with a metal headgasket and it's a much better setup then when the engine was new.
Old Feb 7, 2005 | 07:18 PM
crxdonwon's Avatar
Default Re: (davens)
If you don't have the money for the head bolts you can get them cryotreated. Go to http://www.deepfreezecryo.com it's pretty reasonably priced. They have been proven to get 700% gains in durability. Check it out.
Old Feb 7, 2005 | 07:22 PM
91civicEX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">If your budget is stretched they can be reused. Everybody says once. Some say twice. A handful will tell you they never needs replacing.
Pair the studs with a metal headgasket and it's a much better setup then when the engine was new.</TD></TR></TABLE>
and its easier to install and reinstall the head with the studs.
Old Feb 7, 2005 | 07:27 PM
d16efsedan's Avatar
Default Re: (91civicLX)
ok i looked at some at arp but i dont see any for d16a6 only for d16z6 and y8 i think would the z6 ones work?
Old Feb 7, 2005 | 07:38 PM
efcivic757's Avatar
Yeah The Z6 should work.
kolk1
Feb 28, 2023 12:08 PM
marshall12395
18
Apr 14, 2013 10:07 AM
Egpower88
Feb 14, 2009 11:15 PM
oranginal
May 2, 2006 10:20 AM
tuan...
Nov 28, 2003 02:43 PM
