idle problem!!!
just put toda b's in my b16...fresh valve job, springs, ret. skunk manifold, jdm itr t.b....if i start it it will idle for like 20 sec. then shut off...while driving it runs but when i come to a stop it shuts off again...help?
what kind of springs are you running?
I have the B's, and honestly my caR does stall sometimes. You shoudl have some sort of managment if you don't becayse the stock ECU won't run the car on those bigger cams.
And if you DO have hondata, you need tuning.
Also, are you sure the cam gears and timing belt were installed and set correctly?
B16beatdown
Jul 28, 2008 01:30 PM
