HELP ON SWAP!
Old Feb 7, 2005 | 03:28 PM
Gumbey75's Avatar
Default HELP ON SWAP!
ok wired everything up today and turn the key and it just cranks and cranks. its getting fuel cause i undid the fuel line a little and fuel came out. how do i check if theres air/spark? im using the same dizzy off my 88 hf to a sohc zc plugged right in. may the timing be off? no spark? someone help me out please!
Old Feb 7, 2005 | 04:01 PM
Gumbey75's Avatar
Default Re: HELP ON SWAP! (Gumbey75)
running on a pm6 and throwing no codes!!!
Old Feb 7, 2005 | 04:12 PM
I8ayellowcrayon's Avatar
Quick check for spark would be to just pull out a spark plug wire and put the end of it very close to the head or block and look for a spark while somebody is cranking the motor over.
Did the motor run before you got it? If so I would say to check the distributor... You may have put it on the cam at 180* out. I've done it before.
Old Feb 7, 2005 | 04:47 PM
Rywire's Avatar
Default Re: (I8ayellowcrayon)
180 off is a good suggesion, also check your grounds.
Ryan
Old Feb 7, 2005 | 04:53 PM
drdisco69's Avatar
Default Re: (droppedcrxsi)
Can you put those on 180* off? I know on the b series one of the pins on the key that goes into the cam is larger than the other, preventing you from putting it in backwards. I was under the impression that's how they all were. Forgive my lack of knowledge of d series.
Old Feb 7, 2005 | 05:11 PM
crxtreme89h's Avatar
Double check you plug wires. Make sure they are in the correct firing order.
Old Feb 7, 2005 | 05:15 PM
Default Re: (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Can you put those on 180* off? I know on the b series one of the pins on the key that goes into the cam is larger than the other, preventing you from putting it in backwards. I was under the impression that's how they all were. Forgive my lack of knowledge of d series.</TD></TR></TABLE>
Yep. The only thing to let you know which side to go by is a mark on the dizzy.
Old Feb 7, 2005 | 05:40 PM
Gumbey75's Avatar
maybe a stupid question but do the axels have to be in the tranny? cause i havent put that on yet since i wanted to see if the engine would turn over.. help!
Old Feb 7, 2005 | 06:44 PM
88crx-si's Avatar
Default Re: (Gumbey75)
"bump" for the guy who needs to get his zc running...
Old Feb 8, 2005 | 02:15 PM
Gumbey75's Avatar
Default Re: (88crx-si)
bump still not running~!
Old Feb 8, 2005 | 03:02 PM
EF9TORRES's Avatar
was it originally a dual piont motor? if so did you wire up two more injectors. (convert to mpfi)
Old Feb 8, 2005 | 03:10 PM
Gumbey75's Avatar
Default Re: HELP ON SWAP! (EF9TORRES)
im using my hf wiring harness... m-p already.
Old Feb 8, 2005 | 04:38 PM
Gumbey75's Avatar
ttt
Old Feb 9, 2005 | 11:35 AM
Gumbey75's Avatar
should i use the si harness?
Old Feb 9, 2005 | 01:16 PM
CRX Toad's Avatar
Si harness isn't going to help you. You'll need to convert the DX harness.
Old Feb 9, 2005 | 01:25 PM
Gumbey75's Avatar
Default Re: HELP ON SWAP! (CRX Toad)
why would i have to convert when i have a hf harness
Old Feb 9, 2005 | 01:59 PM
spitzerautomotive's Avatar
If you have an HF or Si you don't need to convert it's already MPFI. What swap are you using??
Modified by spitzerautomotive at 3:14 PM 2/9/2005
Old Feb 9, 2005 | 02:45 PM
Gumbey75's Avatar
Default Re: (spitzerautomotive)
sohc zc
on the zc this is different
Old Feb 9, 2005 | 02:48 PM
untitled's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gumbey75 &raquo;</TD></TR><TR><TD CLASS="quote">maybe a stupid question but do the axels have to be in the tranny? cause i havent put that on yet since i wanted to see if the engine would turn over.. help!</TD></TR></TABLE>
No but damn son, keep that clutch pushed in and dont forget to fill it with tranny fluid after you get the axles in.
Check the rear transmission ground.
Old Feb 9, 2005 | 03:46 PM
Rywire's Avatar
Default Re: (untitled)
Def dont change the harness at all
Old Feb 9, 2005 | 04:02 PM
pyro_freak8's Avatar
do you have your hf engine harness on the zc engine, because when i did my dohc zc swap in my hf i was trying to use an si engine harness on the zc and no luck.... got fuel but no spark, as soon as i swapped over to my old hf engine harness on the zc she started right up
Old Feb 9, 2005 | 04:58 PM
Gumbey75's Avatar
Default Re: (pyro_freak8)
im still using my hf harness but there 1 thing unplugged. and its that thing in the pic' above someone tell me what that does!
Old Feb 10, 2005 | 11:28 AM
Gumbey75's Avatar
Old Feb 10, 2005 | 03:08 PM
Gumbey75's Avatar
ok changed spark plugs and spark plug wires and a new sound is "JUB JUB" wat else&gt;?
Old Feb 10, 2005 | 04:03 PM
Rywire's Avatar
Get that timing on the money bro!
