wires pop out
ok every time i open my hood and check my wires(sohc)i push them down and they click again(MSD 8.5)IS THAT normal do u guy have this probblem.car runs fine but just worried
my opinion, throw out your plugs and wires you got now and get oem, ngk, or denso replacements. unless if you're running a diffferent than stock ignition setup (dizzy, coil, icm), don't use different wires than oem. you will just cause yourself more problems.
As long as I dont have to take out any more Metal Gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon »</TD></TR><TR><TD CLASS="quote">my opinion, throw out your plugs and wires you got now and get oem, ngk, or denso replacements. unless if you're running a diffferent than stock ignition setup (dizzy, coil, icm), don't use different wires than oem. you will just cause yourself more problems.</TD></TR></TABLE>
I agree. I had aftermarket plug wires, car ran like crap, until i switched back to stock. There's a thread out there that compares other wires to stock, and stock always came out on top.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one »</TD></TR><TR><TD CLASS="quote">
I agree. I had aftermarket plug wires, car ran like crap, until i switched back to stock. There's a thread out there that compares other wires to stock, and stock always came out on top.</TD></TR></TABLE>
yeah I know a retard that blew out two ICMs with his gay *** accel wires, and champion plugs. The worst thing that he wouldn't believe me. Stock wires and new ICM I guess the problem was fixed.
A lot of aftermarket plug wires pop out. Swap back to an OEM ignition (there are Hondas that make upwards of 3-400 whp on them) and that should cure all that ails you.
